Thread: Pump run time with infloor system and variable speed pump
    May 2016
    Houston, TX
    2
    Hi there! I'm new to TFP and working on transition to liquid chlorine from Trichlor after noticing decreased clarity and very "slight" algae growth on a few small areas around pool. my FC was 5 but since my CYA is 80, I clearly need more FC. Don't really trust the pool stores and all the algea killing products. So working on getting the CYA down and transitioning to liquid chlorine. Pool build 6 months ago.
    So as I head into VERY HOT summer months here in Texas, I'm wondering how long I should run the pump. It's a variable speed so I can program it however I'd like and I also have an infloor system to clean, etc. Is it okay to not have it run at all for a period of time each day? or should I just leave it on a really low setting continuously? I took the trichlor pucks out of the in-line chlorinator which is at pool side; I had initially been running pump to keep FAC levels correct.
    Thanks!
    Janine
    Ingound, 22,000 gal Chlorine pool, Hayward cartridge filter, A&A infloor cleaning system
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Pump run time with infloor system and variable speed pump
    Mark
