Results 1 to 7 of 7
Thread: What do you think of this calcium chloride?
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    I found this source for a 50 lb bag of calcium chloride de-icing pellets. The label says it is 94-97%. With shipping the cost is less than $1/lb, the best I have found. Does it look safe for pools? Do I need to worry about what else might be in it? Just wanted opinions before I ordered. Thanks!
    Excel Calcium Chloride Ice Melter | GEMPLER'S
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    Aug 2010
    Dallas, TX
    4,052
    Re: What do you think of this calcium chloride?
    I considered that for mine, but got nervous about the "other stuff" in there. If you can catch it on sale, you can usually get the hardness plus products from Leslie's or other pool stores for the same price, about $1 per pound. In fact, I recently got mine for under $1 per pound by simply asking for a discount, and that was from Leslie's!
    JamieP's Avatar
    May 2011
    1,135
    Quote Originally Posted by RobbieH View Post
    Thank you! Maybe I will try that at my local Leslies. It can't hurt!
    I found this same product on Amazon in a bucket (seems preferable to the bag for sealing purposes) but about $1.10/lb with shipping. Someone listed the chemical contents in the questions section. Does the "other stuff" look especially problematic so I should forego this product altogether?
    "The MSDS shows CHEMICAL ANALYSIS
    Specification, Typical
    Calcium Chloride (CaCl2) % 94 MIN, 94.0
    Alkali Chlorides (as NaCl) % 5 MAX, 4.0
    Magnesium (as MgCl2) % 0.02 MAX, 0.01
    Other impurities (except moisture) % 0.20 MAX, 0.10"
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,802
    This is what I used...same thing different brand. I was buying other stuff to get me over $50 for free shipping. No ill effects noted.
    http://www.walmart.com/ip/Snow-Joe-M...ingMethod=p13n
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    JamieP's Avatar
    May 2011
    1,135
    Quote Originally Posted by bmoreswim View Post
    Perfect! Thank you. I'm sure I can find enough else to buy to get the free shipping.
    Mar 2016
    Bakersfield, Ca
    20
    It's on clearance at Home Depot 50# for $13.90. I got this in the 25# bag, and it has a small amount of dolomite (CaCO3/MgCO3) for traction. It will eventually dissolve, or be vacuumed up.
    Snow Joe 50 lb. Re-Sealable Bag Calcium Chloride Crystals Ice Melter-MELT50CC - The Home Depot
    The NaCl (table salt) is what bleach and muriatic acid eventually leave in the water, so not a problem.
    12,000 gal concrete IG, Sta-Rite MaxEGlas 3/4 HP pump (230v 8A) Sta Rite System 3 Filter, Hayward Ultra crawler.
    10% Bleach bottles on bottom of pool. AquaChek 7 Strips, Clorox SmartStrips, Bakersfield City water.
    JamieP's Avatar
    May 2011
    1,135
    Quote Originally Posted by VWFeature View Post
    Thanks... It's helpful to have multiple options.
