Thread: Assistance with Jandy Aquapure error 170
    Jul 2014
    Durham NC
    6
    My Jandy Aquapure started beeping and produced an error code of 170. I consluted the manual troubleshooting guide here: http://www.pleasurepoolsno.com/wp-co...g%20Manual.pdf
    I tested the Transformer voltage (Pins 1-8) which read 79 - should be 75
    Pins 2-7 read 69 - should be 65
    Pins 3-6 read 21 - should be 21
    Pins 4-5 read 0 since cell will not turn on
    Front board test with sensor disconnected
    Expected 2.8 - actual 2.8
    Expected 75 - actual 74
    Expected 91- actual 90
    I am trying to figure out if these reading mean the transform is bad (not within range) as well as the front board (not within range either) or if a bad transformer is leading to the bad readings on the front board?
    Anyone have any advice on this situation?
    Thanks!
    16K gunnite pool and spa with spillover. AquaLink RS system with PDA remote, 1.5 hp Pentair WhisperFlo (primary), 2.5hp Pentair WhisperFlo (spa), Pentair Clean & Clear 320 cartridge filter, Polaris Halcyon Booster pump, Jandy Laars II 400kbtu heater, Jandy AquaPure PLC1400 SWG
    Jun 2015
    Charlotte, NC.
    82
    Re: Assistance with Jandy Aquapure error 170
    I'll let more experienced people correct me if needed, but those voltages don't look bad. Well within natural variations I think.
    I can't pull up the pda for some reason, what else does error 170 point to? I think the transformer and board voltages are good enough
    - Matrioux
    2007 18K pebble IG pool - Wincor Pool Systems automation & SWG (under development) - DE Jandy DEL60 Filter - Jandy 1HP Pump - TF-100 Test Kit
