Thread: Streaky pool walls
    Streaky pool walls
    Hi All,
    This started last year. The walls of my pool are streaked kind off brownish. Not the floor though. I tried scrubbing them and the chlorine, stop yellow routine but it didn't work. What causes this and what can I do about it?
    Winter Park FL, 10,000 gallons, surfaced with marbeletite 5 years ago, 1.5 hp filter and DE Filter.
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    475
    Re: Streaky pool walls
    Sounds like metal stains. To be sure, try rubbing it with a vitamin C tablet. It comes off like magic if it is metal staining.
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Read this
    Diagnosing Pool Plaster Problems
    and this
    Pool School - Calcium Scaling
    and this
    Pool School - Metals in the Water and Metal Stains
    Give us some test results. A few of the last sets if you keep records. Especially PH, CH and TA.
