Results 1 to 8 of 8
Thread: Cleaning the cell.....
    Oct 2015
    San Diego, Ca.
    649
    I am going to have to clean out a salt cell with a 4:1 Muriatic Acid wash. I don't have the fancy "end cap" to hold the solution in the cell while it fizzes away.
    Is it possible to just pour the solution in a bucket and place the cell in vertically (keeping the cord and plug out)?
    P.S. no one really talks about 31% or 18% acid for this?
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    Aug 2010
    Dallas, TX
    4,052
    Re: Cleaning the cell.....
    Some you can, some you can't. You can probably go to your local hardware store and get a screw-on PVC cap, too.
    31%
    38,475
    I was too cheap to buy the fancy end cap and the threads are proprietary ... so, I used ... duct tape.
    I put a couple over lapping strips across the bottom and wrapped them up onto the threads and then put a strip around the threads. It only needs to hold for a few minutes and I had no leaks.
    Use at your own risk
    Jun 2011
    Long Beach, CA
    2,790
    You can use a rubber winter pool plug. Find a size that fits your cell, works great.
    JoyfulNoise's Avatar
    May 2015
    13,247
    Rubber handball works just fine.
    Matt
    May 2016
    Miami, FL
    14
    I don;'t have the end cap, so I've always used a bucket
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Go to the plumbing department in you local Lowes, Home Depot, or hardware store and pick up a 2" test plug. They are located in the pvc fittings area.
    Shop Oatey 2 Dia PVC Test Plug Fitting at Lowes.com
    After installing the plug, I stand the generator in an upended 2" coupling I have.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    Oct 2015
    San Diego, Ca.
    649
    Quote Originally Posted by Propbndr View Post
    PERFECT!
