Thread: Swim season starts this weekend
    Oct 2015
    THE WOODLANDS, tx
    65
    Hi all,
    I've been maintaining my pool since last Oct using the TFP method. This is the first weekend we're going to be swimming with company (no pressure! ) These are my current levels:
    FC 8 (Got a little too excited!)
    CC 0
    pH 7.6
    TA 50
    CH 190
    CYA 40
    I know I have to raise CH but haven't gotten around to ordering it yet. I was thinking of lowering pH to 7.2. Would that be wise? I could raise CYA but I'm going to out for 2 months in the summer and having to hire a pool co. and they'll be using pucks.
    If there's a heavy swimmer load (no babies/toddlers) the main contaminants will be sun block and bug spray.
    1. So if swimming starts saturday morning, what time should I test the water and add chemicals?
    2. How long after adding chemicals can people go in?
    3. Should I test at the end of the day as well?
    4. Anything else?
    Thanks as always for helping
    ~20,000 gallons, IG white plaster, Cartridge filter (make unknown), Filter Pump (Jandy Stealth Model # SHPM2.0), Probably over 10 years old, Spa, non-functional SWG (bad sensor), Taylor K-2600
    Jun 2014
    15,008
    Re: Swim season starts this weekend
    Your numbers look good right where they are - except CH. But you're on that already. I wouldn't lower pH to 7.2 just for them though. Maybe Friday adjust if it's at about 7.7-7.8.
    For your questions:
    1 - Test water early Sat morning and adjust. It's all good after mixing for about 30 min anyway.
    2 - About 30 min is plenty with pump mixing real well
    3 - Yes, after the party. But if you can't, at least add 1/2 - 1 gallon of bleach to help the pool bounce-back from the stress.
    4 - Yes ... have fun.
    After the party, keep an eye on the TA so it doesn't drop below 50. Especially if your pool requires frequent acid for the pH, it's always bringing the TA down with it, so just be mindful of that as well. Enjoy!
    38,251
    I would actually leave the CH as it will tend to rise due to evaporation anyway. Just keep your pH a little higher (like about 7.5) to counter the lower CH.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    With your low TA and slightly low CH, I wouldn't touch the pH unless it rose ABOVE 7.8. Your pH is likely to be stable for a long time in the upper 7s at those levels.
    Isolated Spa - 345 Gallons
    Oct 2015
    THE WOODLANDS, tx
    65
    Excellent. Thank you all!!
