Results 1 to 9 of 9
Thread: Deep cleaning a Side discharge Triton 2 Sand filter
    May 2016
    MD
    195
    I can't deep clean it cause the water runs out the pipes.
    I stuck a hose in it and let it run, and tried dumping buckets of water in it... it all runs out before it pushes over the top
    Any Ideas?
    Triton<sup></sup> C and Triton C-3
    IG, 25k gallons, 20x40 ft, Plaster, Pentair sand filter, variable speed pump, have a well, TF-100 test kit, Speed Stir
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Re: Deep cleaning a Side discharge Triton 2 Sand filter
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    You should turn the multiport valve to off and valve off any other pipes. As YS said, remove the top and clean away.
    I have this exact same filter and have done it a couple of times.
    Support the site
    May 2016
    MD
    195
    o.... the other pipes... that may be why... ah... Silly Newb
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Puppiesonacid View Post
    we all have to learn. That is why we help other out here.....
    Support the site
    May 2016
    MD
    195
    Well... I just figured it shut off the whole sand filter... but i did see a gushing in the pool pump well with the basket... need to turn the returns from the pool to closed is what you are saying...
    Thanks
    May 2014
    Franklin, NC
    9,184
    Thanks
    If the pool equipment is lower than the pool, yes. If you don't valve everything off water will flow to the lowest open pipe.....
    Support the site
    Jan 2012
    7,351
    lol... it's all that acid, man. <guffaw!>
    May 2016
    MD
    195
    Ha. it is a song name Dream Theater. And just random enough to use for screen names that leaves people wondering
