Results 1 to 7 of 7
Thread: Help getting water balanced
    Jul 2015
    Independence, KY
    14
    Just opened my pool and the water is crystal clear. Vacuumed a few leaves, worms out and added 4 gallons of liquid shock. Haven't added anything else. My numbers (using Taylor K-2005 test kit):
    Chlorine - 10-20
    pH - registering greater than the highest mark (8)
    Alkalinity - 170
    Calcium - 270 (actually turned purple not blue)
    CYA - 50
    Should I add anything or wait for chlorine to come down?
    16x32 inground vinyl pool, 23,000 gallons, Hayward sand filter, built 2013, Taylor K2005 test kit, Dolphin cleaner
    Aug 2010
    Dallas, TX
    4,052
    Re: Help getting water balanced
    Did you test before or after adding the chlorine?
    Sep 2014
    Fort Lauderdale, FL
    146
    Robbie is asking because high chlorine (over 10ppm) can invalidate the results of the ph test.
    With the numbers posted above, both pH and alkalinity are high (and they're related, higher alkalinity tends to drive a higher pH). Fortunately, they can be adjusted together. You'll want muratic acid for that. But first, you want to make sure you have a proper pH result.
    ONLY DO THIS AFTER YOU'RE SURE OF YOUR PH LEVEL: The process is generally to use poolcalculator.com to determine how much muriatic acid is needed to reduce pH to 7.2. Add that amount all at once with the pump running. The act of dropping the pH sharply with acid will lower alkalinity a bit. Wait a bit and re-measure both. Then, it's lather, rinse, repeat. You'll end up doing this a few times, maybe over a period of days, until alkalinity falls where you want it. 70 to 90ppm is generally recommended as a target, although it's ok to be a bit outside this range as long as pH falls where you want it. Every pool is a little different when it comes to pH and where it tends to drift. I find that I have to keep mine on the low side, around 70ppm, to keep my pH from going above 7.8.
    15k in-ground plaster, Hayward C900 cartridge, 1.5hp Pentair SuperFlo VS pump, Hayward AQR15 SWG, Barracuda G2 suction cleaner, TF-100
    Aug 2010
    Dallas, TX
    4,052
    I don't believe Pool Calculator is being maintained anymore unless something changed recently. Instead, we recommend Pool Math at the top of the page.
    http://www.troublefreepool.com/calc.html
    Sep 2014
    Fort Lauderdale, FL
    146
    Good to know...I'll have to update my bookmark!
    Jan 2012
    'burbs of Augusta, Georgia
    7,316
    The K-2005 test kit won't give you the FAS-DPD test you *need* to read FC over 10.
    You can order that part of the K-2006 kit here: TFTestkits.net
    Jul 2015
    Independence, KY
    14
    I added the chlorine yesterday evening and tested this morning.
