Thread: Trying to remove hayward multiport valve to replace plastic o-ring that handle sits o
    Having some trouble getting the valve off to replace a dry rotted o-ring. I have removed the 6 screws, but the top doesn't want to come apart from the bottom. It seems like something is keeping it from coming off. Is my valve just old and stuck in place or is there something else going on? I can get a screwdriver between the 2 halves, but I don't want to force it off and break something.
    20000 gal inground vinyl liner, HTH 6 Way test with Taylor FAS-DPD for CL, Dolphin DX4 Cleaner
    pookiesunshine's Avatar
    May 2016
    Cincinnati, OH
    435
    Re: Trying to remove hayward multiport valve to replace plastic o-ring that handle si
    Probably just stuck. try tapping it with a rubber mallet or prying gently with screwdriver. btw, i assume you are talking about a spider gasket. there are many youtube videos on multiport valves. i didnt realize there were so many different models.
    30000 gal inground vinyl liner;sand filter w/glass media, nuvo uv, TF-100 test kit; 25 years on Baquacil, converted to TFP chlorine in 2016
    No, there is a white plastic o-ring that sits below the handle that can be seen from outside the filter. It's dried out and breaking into pieces.
    May 2016
    Cincinnati, OH
    435
    that might be harder. i remember [vaguely] doing that many years ago and had a heck of a time getting the handle off/on. i was probably doing it wrong. Here is a link to replacing the spring (which you are not doing) and the white gasket you are wanting to replace. It shows how to compress the spring to remove the handle pin. i wish i had found that when i did mine.
    How To Replace a Pool Multiport Valve Spring - INYOPools.com
    since your valve top part is stuck, you may find you have a bad spider gasket too. just a guess.
    I got it off. Just replaced the entire top half with a spare I had. Thanks for the help
