Results 1 to 8 of 8
Thread: TA, CH & CYA Numbers Dropping
    Mar 2016
    Albuquerque, NM
    19
    Question TA, CH & CYA Numbers Dropping
    Hello All. I'm a newbie and noticed my numbers for TA, CH, and CYA have dropped since I tested 3 days ago. My pool is brand new, so is this normal during the plaster curing process? My numbers when I tested on 5/22 were:
    TA - 130
    CH - 350
    CYA - 40
    My numbers this morning:
    TA - 110
    CH - 175
    CYA - 20
    My CC was 1.5 on 5/22 so I have been adding liquid chlorine to keep my FC around 9. This morning my FC is 9 and my CC is 0.5. The water has been clear and my pH has been between 7.4-7.5.
    16K gal, IG, plaster, Hayward TriStar VS Pump, Jandy CL580 Cartridge Filter, Raypak 266 Heater, Pentair WhisperFlo single speed Water Feature pump, Stenner Liquid Chlorine pump, Zodiac MX-8 Suction Side Cleaner, Automatic Pool Cover, TF100 Test Kit w/Speed Stir
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: TA, CH & CYA Numbers Dropping
    Have you had a massive (50%) water exchange?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mar 2016
    Albuquerque, NM
    19
    Quote Originally Posted by Mr Bruce View Post
    Nope. Not sure if it's a pool issue or my testing methods. I don't want to start adding chemicals until I know for sure.
    Aug 2010
    Dallas, TX
    4,052
    Do you have an auto-fill?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    CH I could see if you did a 25ml sample one time and a 10 ml the next. CYA is hard to mess up quantities.
    The one that alarms me the most is CH, if you just had new plaster. I would do that one again with someone else, read the card out loud and verify each step.
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Quote Originally Posted by RobbieH View Post
    Yeah, that was my first thought too. If the pool had an occult leak that wasn't detected because of the autofill.
    Would you hear the water coming on and off though?
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by YippeeSkippy View Post
    You could not hear mine. But you can't hear any of my equipment at the pool.
    Mar 2016
    Albuquerque, NM
    19
    No, but I did add some water yesterday to get me half way up the waterline tiles. The water was approx 1/4 above the tiles before doing so. My PB came over yesterday to check out the equipment and told me to add water.
