Thread: Got my FC to high
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Got my FC to high
    Went out of town for 3 days, and I turned up my SWG a little to high. I wanted to make sure I had plenty of chlorine in the pool on these full sunny days. FC was at 11 this morning when I got home. Do I just let it drift back down over the next couple days? Water is clear and 0 on CC even though there were 3 baby moles in the skimmer.
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Aug 2010
    Dallas, TX
    4,052
    Re: Got my FC to high
    Yep, just let it drift down.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    If you've been maintaining CYA anywhere above 20, you're still well below shock level. It's safe to swim in right now. Just kill the SWG for a day or two and it should drop down to normal.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    CYA tested at 70 last Friday!
    Mark
