Results 1 to 20 of 20
Thread: Cyanuric Acid - Brands/Quality/Questions
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    CYA - Being a SWG user, I know I need to keep CYA on the high side. I am shocked year after year, how low it gets from dropping a few inches of the water level for the winter. But it does. I need to bring it up from 30 to about 75.
    I will need about 15 lbs. This can get expensive. Any brands you guys recommend? I love getting stuff on Amazon Prime and I can get 2 bags of this stuff.
    Amazon.com : Pool Mate 1-2607B Stabilizer and Conditioner for Swimming Pools, 7-Pound : Patio, Lawn Garden
    But I know nothing about the brand. Am I compromising quality here? If so, what do you guys recommend? Leslies is very convenient for me to go to as well if you like their stuff.
    Also when I do the test on the Taylor Kit (Where you keep adding the drops till the black dot disappears). I just did this test yesterday which is 3 days after opening pool and topping off water. The dot Never disappeared. And I think the highest mark on the vial (the lowest reading) is 30. Can it really have dropped this much over the winter when I was running at 70 last year? (I dropped water about 3 inches below tile line). FYI - It's like this every spring.
    One other thing to chime in on. If you test for CYA during a time of elevated pH, will you get an inaccurate CYA reading? I just find it hard to believe I am getting no CYA reading on my black dot test.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Aug 2010
    Dallas, TX
    4,052
    Re: Cyanuric Acid - Brands/Quality/Questions
    CYA can drop during the winter, and certainly drops when you replace water. I just added 5 lbs to mine, so I know what you mean.
    I'm picking on myself here, there's nothing cheap about maintaining a pool, especially when they are 38-44k gallons as ours are.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    15 pounds of CYA just makes me shiver......
    Pool Math came up with a hair over 13 pounds when I ran your numbers (I went to 70).
    That product is fine
    I also like Amazon but would compare to the stuff at Lowes. Pool $tores are usually the last place to buy.
    Support the site
    Aug 2010
    Dallas, TX
    4,052
    It took 25 pounds to bring mine up after the replaster!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    It should be all right.
    14 lbs for $54.98
    I also see 16 lbs for $53.57 (w/shipping) on that page. Compare to 4 4 pounders at Walmart for $51.08.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Cool guys. Just the fact that I am seeing Lowes and WalMart suggestions here answers my question about paying premium prices in pool stores. re reading what I wrote earlier, I sound cheap. I really don't mean to come across that way. Just why pay more if it's all the same stuff. Now I am ashamed I brought that up.
    Aug 2010
    Dallas, TX
    4,052
    It's OK. The stuff from WalMart is fine. I use Leslie's, but when I buy, I buy so much bulk, they give me a break. But, this is at the Commercial store, not the retail store, so that may help. And, that way I don't have to walk into a WalMart.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Amazon has the same Clorox product carried in WalMart at the same price:
    Amazon.com : Clorox Pool Garden
    I just placed an order for 4 of them.
    Richard320's Avatar
    Jan 2010
    19,009
    Quote Originally Posted by mikemass View Post
    Why?
    We're all cheapskates.
    If the pool store is competitively priced, I don't mind shopping there. But when you can get the identical chemical for much less by sacrificing the fancy packaging, why not? Baking Soda is the one that always springs to mind. Leslies, in the large economy size, 50 lbs for $62.99. Walmart 4 lbs $2.35. So.... $1.26 versus 59 per pound? That's more than double! If you opted for the smaller 5 lb canister at Leslies, it's $2.80 per pound! That's almost 5 times as expensive!
    No apologies needed.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    I knew there was another question I had about CYA:
    Sometimes referred to as a "sunscreen for pools". Does blocking the UV light from the pool effect the sun's ability to heat the pool? All things being equal will a pool with a high CYA not get as hot as one without high CYA?
    And TY sir. When said that way, who can argue?
    Richard320's Avatar
    Jan 2010
    19,009
    No. The CYA binds to the chlorine to slow down the breakdown. It doesn't reflect the UV or shade the pool.
    Jul 2015
    Western NC
    115
    Walmart and Lowe's is not a solution if you open early and close late, at least not around here - everything must be pre-ordered at Lowe's and Walmart only has a pool section during the "normal" swimming season. Amazon is a better option, and they deliver to your door too.
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Sparkle View Post
    Where in "Western NC"? It may be store specific. The Lowe's in Franklin had CYA on the shelf all winter, sitting all lonely out in outside garden.
    Support the site
    Jul 2015
    Western NC
    115
    Not true. Some of us are willing to pay more to get stuff you consider unnecessary.
    For instance, I buy 20% MA and that costs me more money than the stronger acid would.
    I wouldn't drive across town just to get 50% off on the same product, either. It just doesn't matter to me whether I spend $4 or $8 on it.
    Quote Originally Posted by tim5055 View Post
    They told me - at that exact store - that they didn't carry any pool products unless you pre-ordered them. That was less than a year ago, and CYA was what I was looking for at the time.
    May 2014
    Franklin, NC
    9,184
    P
    They had salt, though.
    I have found the staff, including management at that store to be less than stellar.
    Support the site
    Jul 2015
    Western NC
    115
    That's a good way to put it. ;o)
    Mike Hawk's Avatar
    Oct 2014
    Tulsa OK
    51
    Right now you can get 25lbs for $44.99 shipped off ebay. That works out to only $1.80 a lb!!! WOOT!
    I am (well, was) paying $4.06 a lb for the stuff at Home Depot (HDX brand). Yup, definitely gonna dig out my receipt and do a return to home depot!
    2007 Gunite 15k Pump: Whisperflo Motor: B2983 2spd 2.2/0.28 SFHP Sand Filter: TR100 SWG: Aqua Rite T15 Timer: PF1102T w/ redneck SPDT toggle switch Vacuum: Milliard 19" manual / PoolCleaner 2X auto
    Oct 2015
    Katy/Texas
    411
    I just ordered 7# from Amazon and it will be delivered SUNDAY!
    The advantage of living in the big city.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Jul 2015
    Western NC
    115
    Slightly off topic, but anyway...
    In retrospect, I'd say you've seen nothing unless you've tried to buy an 8ft cattle panel from Tractor Supply.
  20. Back To Top    #20
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,153
    Remember you can donate to this forum anytime you order from Amazon. Just link your Amazon to Troublefreepool AmazonSmile: You shop. Amazon gives. It is easy and costs nothing.
