Results 1 to 18 of 18
Thread: Elevated CYA and Algae
    May 2016
    winchester, MA
    11
    I recently purchased a house with a pool and trying to open it for the summer.
    It has algae, elevated CYA of right between 80-100 and elevated Phosphates. I bought Poly 60%, phosfree, and dropped water in the pool by almost half for the CYA.
    So what do I do first?
    1. Fill it first. Then add the Phosfree and Poly 60% and Shock?
    2. Phosfree & Poly60 First, then fill, then shock?
    3. Other?
    Any help would be greatly appreciated.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Elevated CYA and Algae
    3> OTHER! You need to order one of our recommended test kits and take control of the beast. Phosfree= waste of money. Poly= waste of money, will not CLEAR algae. We don't SHOCK anything. Return that stuff if you can and invest in liquid bleach. We SLAM it! Please give us all your pool parameters in a signature line in your profile. Than read Pool School ABCs and how to SLAM your pool and what is required. Welcome.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Welcome to TFP!
    Background
    Pool School - Defeating Algae
    Short version
    Pool School - SLAM - Shock Level And Maintain
    Long version of how to get rid of algae
    Turning Your Green Swamp Back into a Sparkling Oasis
    What we need in a signature to better help you, Pool School - Read This Before You Post
    May 2016
    winchester, MA
    11
    All other parameters are in order. I'll get you the exact readings tonight but pH, Ca, TA are all in normal range. I presume I do have to replace half the water to get the CYA into a range so that the SLAM will work?
    So do I -
    1. SLAM with the elevated CYA(80-100) in 15k gallons
    2. SLAM with in line CYA (40-50) in a 30k pool
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Welcome to TFP! The methods here are the most economical way to clear your water and keep it clear all season long. There is a lot of information overload at the beginning, but it will sink in and you will be a TFP pool snob soon
    Just keep reading and asking questions.
    Agree with others. Return what you bought if possible. Order one of the recommended test kits, the TF-100 XL is the most economical option when you need to SLAM.
    Link to the most economical kit:
    TFTestkits.net
    Once you get one of the recommended kits, post up a full set of results. The upper limits of the CYA is 100, if you are above 100, you should dilute 50% pool water with 50% tap water.
    In the mean time, go buy a bunch of plain bleach (no splashless, no outdoor, no scented), plain Wal-Mart brand bleach is generally easy to find and economical. Once you fill in your signature with your pool details so we can tell you how much bleach to add each day while waiting for your test kit.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    You'll be happier in the long run with lower CYA. That means some water replacement.
    You don't want to add Phos-free to a green pool. Even the manufacturer warns against it, but the pool store clerks only see dollar signs, so they push it. What happens is you end up with thousands of gallons of water that looks like milk. It should only be added to an algae-free pool.
    You don't want to add algaecide now, either. It's a preventative, not a cure. It's like putting SPF30 on a beet-red sunburn. It doesn't relieve the pain, and in fact, rubbing it on only increases the suffering. The time for algaecide was at the end of last season, so you wouldn't open to a green pool.
    So if your pool is already half empty, fill it up and get it circulating at least half an hour and brush the thing so you get things mixed even in the dead spots. Then test it all. If CYA is still too high for your liking, drain some more. If you have the ability to vacuum to waste, that's a good way to remove water and sludge simultaneously. That depends on your equipment. Please fill out your signature so we can stop speculating and give answers tailored to you.
    Once you know the CYA level and have the pH in range, you bleach the algae into submission. We call that the SLAM. It's like a pol store shock, only under control and sustained long enough to actually work.
    Here's a few links. Look at the pictures. Read a little. Do what they did.
    May 2016
    winchester, MA
    11
    Thanks everyone. I'll follow up with more technical details of the hardware tonight.
    40x16x(4-8) 30k gallons, vinyl pool in heavily wooded area. Pump unknown, Hayward 48ft2 DE filter.
    May 2016
    winchester, MA
    11
    Ok,
    ph - 7.6
    Fr Chlo - 0
    TA - 100
    CYA - 90
    I've drained somewhere between 1/3 to 1/2 half of the 30k pool.
    So do I
    Slam now, then refill?
    or
    refill then slam?
    Richard320's Avatar
    Jan 2010
    19,074
    Quote Originally Posted by hubs99 View Post
    Ok,
    ph - 7.6
    Fr Chlo - 0
    TA - 100
    CYA - 90
    So do I
    or
    refill then slam?
    Refill. You must have good circulation to SLAM, and that won't happen with low water.
    May 2016
    winchester, MA
    11
    Thanks Richard. I'll keep you posted on the progress.
    May 2016
    winchester, MA
    11
    Update - Shocked with 8.25%, and went up to low 20's. FC is down into the 3ppm range but the pool is still very cloudy.
    Should I reshock tonight or wait for the OCLT in the morning?
    Richard320's Avatar
    Jan 2010
    19,074
    Keep the pool at shock level until it passes the overnight loss test AND CC is .5 or less AND the water is clear, even after brushing. That's the M in SLAM. Shock Level And Maintain. The Pool store will tell you to blast the pool with chlorine and forget it.... which is why the pool never gets clear. Algae didn;t take over in a day ore two, so it'll take more than a day or two to get rid of it.
    May 2016
    winchester, MA
    11
    OK, Round 2. How often should I be backwashing? Only when the pressure jumps?
    Thanks again. We'll see what the morning brings.
    Richard320's Avatar
    Jan 2010
    19,074
    When the pressure rises 25% over clean pressure OR you notice diminished return flow. And maybe a full teardown when the SLAM is all done just to get it really clean. Backwashing never removes all the DE. DE Filter Cleaning Tutorial
    May 2016
    winchester, MA
    11
    We had an overcast day and my FC stayed 10 all day. Should I bounce it back overnight? Or should i presume the organic matter is fried its just dead particulate that needs to be filtered?
    The water continues to be cloudy, FC 10, pH, TA, CYA all normal range.
    Richard320's Avatar
    Jan 2010
    19,074
    SLAM says keep it at shock level until: CC is 0.5 or lower AND you pass an Overnight Chlorine Loss Test AND the water is clear all at the same time. I don't see any of those yet. Don't stop too soon, or it will return.
    May 2016
    winchester, MA
    11
    Richard - Thanks for all your help - The pool has been green free for close to a week and I could not be any happier. Hopefully I won't screw it up.
    Richard320's Avatar
    Jan 2010
    19,074
    Now's when you coast. Just don't coast too long. Keep the FC up and the pH in range and brush and vacuum once in a while and that's all there is. The pool will just keep getting clearer and clearer and someday soon someone is going to come over and see your sparkling pool and freeze and say "Wow!"
