Thread: Long Crack under coping.
    May 2016
    Phoenix/AZ
    11
    Hopefully this is the best place for this.
    New to pools and unfortunately we didn't notice this crack surrounding half the pool. Its between the top of the tile and the coping. At first I thought maybe it's just grout, but the crack is pretty deep. The depth and width varies as you go around the pool. It's as if the concrete is lifting. I guess you could say it's a cantilevered concrete deck and not typical coping nased on what I have seen. What's the best way to fix this?
    I can't figure out how to upload a photo from my phone.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Long Crack under coping.
    Welcome to TFP!
    Polyurethane caulk is probably best.
    May 2016
    Phoenix/AZ
    11
    Quote Originally Posted by pooldv View Post
    Welcome to TFP!
    Thanks and Thanks!
    Should I use backer rod?
    Picture below. That's about half an inch wide, but deep.
    May 2016
    Phoenix/AZ
    11
    Quote Originally Posted by blakeaz View Post
    Thanks and Thanks!
    To clarify, it's about a half inch high and circles about a third of the pool. What would be the proper way to fill this? Backer rod then caulking? Thanks!
    Apr 2013
    Sacramento, CA
    2,769
    This is a moving joint, especially in Arizona. So you don't want to put in anything that would imar the movement of the joint. Do you have a joint between the concrete and the wall? Please say yes?
    Anyway some backer rod and Polyurethane caulk should work. Don't expect it to last more than a couple of years.
