Thread: Program Trouble Variable Speed Pump
    May 2016
    Colleyville
    2
    This is my first post although I've been referencing this forum for the last nine month.
    I have a Jandy PDA that I use to control my Aqualink for my variable speed motor. I've been noticing more and more where the program to switch speeds is not being followed. The pump always comes and and turn off at the correct time. The problem I see is that it should be running at a lower speed according to the program, but it's running at it's high speed. I've tried playing around with the program to do some testing and right now I think it's just an inconsistent thing versus any pattern I can recognize. Anyone see this before or have any suggestions? Thanks!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Program Trouble Variable Speed Pump
    Welcome to TFP
    Sorry no one has seen this yet, it might be a while before someone with the knowledge comes along
    Stick around a enjoy the site
