Results 1 to 10 of 10
Thread: Don't want to use tablets again, but...
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    I was visiting the pool store for suggestions and to buy supplies. The result, last September my CYA was 120+ and I started developing algae problems.
    I discovered this forum and learned what I was doing wrong. Oh, well, live and learn. Thank you for the people here who helped me.
    I have an automatic chlorination for tablets. Don't use it anymore. Only liquid chlorine. I managed to get my CYA down to 60. Not bad for Florida. Now I have to pay attention to the CYA levels so I can kept it in the 60's. The pool is clear and perfect.
    Here is the question:
    I still have plenty of tablets. If my CYA is getting low can I add only one tablet to the automatic chlorinator and leave number of the chlorinator to the minimum of 1 or maybe .05 so it can dissolve slowly? Or it is really not recommended? I am checking my numbers everyday. So I can adjust accordingly?
    Thank you all for your help.
    15K gallons, Plaster, Taylor K-2006C & TF-100, DE, non SWG, Hayward TriStar VS variable pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Don't want to use tablets again, but...
    If you need to raise CYA and you already own the pucks, use 'em up! We're not opposed to pucks under all conditions. Sometimes they're just what you need. As long as you know what you're adding, use them.
    I like to let my CYA dip a little from backwashing and CH reduction, so I have room to use pucks in a floater while I'm gone on vacation.
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Thank you. Good suggestion. Will kept it on mind.
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Quote Originally Posted by trevorfl View Post
    How did you get CYA from 120 to 60? Need to know. Thanks.
    12,000 Gal, InGround, Spa Attached, Satin-Matrix Northshore Tahoe Pebble-Tec, Remodel 6/15, Taylor K-2006 Kit, Pentair IntelliFlo Variable Speed Pump, Polaris 280 Sweep, Jandy CL460 Cartridge Filter, Solar Heated. Taylor K-2006 Test Kit
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Tablets add chlorine. They are acidic, so they lower PH/Alk. They have CYA, so that slowly rises. Understanding what using tablets do to your pool is winning the battle. Because of the offset of what they do to the pool, its what makes them more costly than using the TFPC method.
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Quote Originally Posted by Frankhugus View Post
    It was a long process. I drained the pool but not much. Also, just remembered now. The 120 reading was from a pool store. When I got the Taylor k-2006 kit the cya was actually like 100. I forgot about that until now. We all know how wrong pool store testing are.
    In FL rain a lot during the raining season. Every time the pool was full I "wasted " some water and I think that helped too.
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Makes sense. I'm dealing with "pool store " CYA " now and it's a fight to the finish. I'm going to win.
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Just out of curiosity, what are your CYA numbers?
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Quote Originally Posted by frustratedpoolmom View Post
    Thank you. Will maintain the TCPC method. After all this work I don't want to mess with the CYA again.
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Hanging at 150 and keeping FC above 10. It's a long story but I'm determined to win.
