Thread: New liner, new water....no cya
    Jul 2012
    Forest, VA
    79
    Currently filling my pool that was emptied for a new liner. Cya should be zero. The filling will take another day, add some bleach this evening with no cya to ward off any algae growth or just wait til tomorrow and add cya via sock. There have been no chemicals added thus far and this is day 2. Thanks for any replies.
    12,000 gal Octagon vinyl in-ground pool. Hayward S220 sand filter 3/4 hp pump, heat pump heater
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: New liner, new water....no cya
    You can start adding CYA now in a sock attached to a float this was about 12 inches of water, use poolmath to know how much CYA to add to 30
    adding a cup of bleach would work great..
    Jul 2012
    Forest, VA
    79
    Well I won't have any stabilizer until tomorrow. Could I put 1 puck in my chlorinator and feed slowly?
    Jul 2013
    Fletcher, OK
    3,353
    it will be fine until tomorrow, just add a cup of bleach
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    You don't need CYA at night anyway. No UV from the sun. It'll be okay.
