Results 1 to 8 of 8
Thread: Hello
    May 2016
    Henderson NV
    14
    Hello
    Hi all, wanted to get the kiddos a pool for the summer and found this site while shopping.
    Really happy I found this forum because being a mechanic I like to do everything myself and try to research as much as I can. I bought a cheap test kit from Walmart to get me started but my tf100 will be here tomorrow. Just trying to keep the cl and ph in check till I can test for more. I am already finding myself looking at an Intex sand filter and swcg lol. This little pump that comes with the pool is pretty laughable, but what do ya want for a 70 dollar pool. If I can successfully manage the pool without stressing myself out I already want to upgrade to something like a big Intex pool. Thanks for reading and thanks in advance. Ed
    3200 gal. 15'x33" above ground vinyl pool. Intex 2100gph sand filter w/ type b adapters for my baby size pool fittings. Filled from city water. TF-100 test kit w/ magnetic stirrer. Used trichlor tabs at the start to get cya up. Just using bbb.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Hello
    Welcome. Better equipment makes managing a little larger pool a LOT easier.
    May 2016
    Henderson NV
    14
    Re: Hello
    Thanks Woody, is that Intex Krystal clear sand filter and swcg a decent setup or should I be looking at something else when I upgrade?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Hello
    Welcome!
    Here's something you need to know about. They also sell them in most pool stores.
    Soaks up oils. So if you come home and jump in the pool after getting a 90 weight shampoo or an ATF shower, you won't leave a slick on the surface. If you do leave a ring, Mr Clean Magic Erasers will remove it.
    May 2016
    Henderson NV
    14
    Re: Hello
    Thanks! Makes sense. I've got something similar in the bilge of my boat. Never would of thought of that for the pool.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Hello
    Welcome to TFP!
    Congrats on the new pool. We started with one like that 12 years or so ago. Lots of upgrades since then. The Intex sand and SWG is a nice upgrade from the Intex cartridge filter. Lots of people here use them.
    May 2016
    Henderson NV
    14
    Re: Hello
    Thank you. I believe I will be getting the sand filter for sure. Maybe the swg when we upsize the pool!
    Casey's Avatar
    SW PA
    10,461
    Re: Hello
    Welcome to TFP
