Thread: Using Lithium Hypochlorite to shock
    May 2016
    Roseville, CA
    3
    I recently drained about 1/2 of my pool to bring down the CAL, CYA and TDS. Everything being out of whack is probably from using only Tri-chlor tabs all winter. Before the city would give me a permit to drain, I had to bring my FCL to 0.1. Water is back in and chems are balanced, I just need to re-add Chlorine. I was thinking I should shock my pool also. I only use Lithium now, and no Tri-chlor tabs.
    I was on a different site it says: “Do NOT use dichlor, trichlor or lithium hypochlorite to shock”
    It’s not mentioned why not to use Lithium, but this is my primary source of chlorine. Can anyone help me understand why they don't recommend using it as a shock?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: Using Lithium Hypochlorite to shock
    Welcome to the forum. I deleted the link in your post as a new member.
    Dec 2014
    Sydney, Australia
    43
    Lithium Hypo is ludicrously expensive (in OZ anyway) 2KG AU$88 a quick mess in pool math shows 568g LH ($25) vs 1.5L bleach(12.5%) ($1.20) to do the same thing.
    8M x 4M Inground Concrete, 40k Litres, Waterline Tiles/Quartzon, Viron P320 VS Pump, Sand Filter(Glass Media) Astral VX-9 SWCG, Heatpump w/ Solar Cover. Zodiac V3 4WD Robot. Bullfrog A8D Spa(1800Litres).
