Results 1 to 13 of 13
Thread: CYA for my scenario
    May 2015
    Land O Lakes, FL
    527
    CYA for my scenario
    Tampa, FL
    Full sun from about 1130am
    Screen enclosure
    Firing up SWG this weekend
    Based on everything that I have read and the recommendations for Salt Water Systems in full sun I need to be at the high end of the spectrum do you agree?
    Thank you
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Jun 2014
    15,217
    Re: CYA for my scenario
    I would certainly start at a CYA of 70 and if you need more based on FC loss, then increase from there. Always easier to go up than down.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Target 80. But if it turns out mathematically that to do so would require 1.1 canisters of CYA, settle for less so it comes out nice and even. The range is 70-80, so you'd still be covered.
    May 2015
    Land O Lakes, FL
    527
    Ok, thanks, i am at 50 to 60 now, going to test again now to confirm and see how much more i need, .
    Matt
    May 2015
    Land O Lakes, FL
    527
    I am at 60, so i will take it up to 70 and retest
    Matt
    30,431
    Well, my experience with screens would actually suggest less. That screen blocks an incredible amount of UV (you have to run your heater all summer, right?)
    The UV that actually touches your pool is probably only 70% of a pool without a screen.
    I would suggest a CYA of 50 ppm to start perhaps moving to 60 as the summer progresses
    May 2015
    Land O Lakes, FL
    527
    You are correct that it blocks about 30% of the suns rays. I don't think I will need it through the summer unless I wanted the temp regularly closer to 90 but time will tell. We seem to like the temp between 84 and 86 as adults. Kids are fine down to 80 or so for sure or even less. We will probably be setting the solar to cut off at about 83 and let the sun heat is up a few more degrees through the afternoon. Right now it is dropping down to about 79 overnight.
    The last several days, I have been losing 3-4 ppm of Chlorine daily I believe but I have not been methotical about checking the before and after, just making adjustments as needed as I have been bringing my CYA up. It is getting to be about 90 in temperature and we are swimming just about every day and when we swim, it is up to 7 kids with just my family. Today, there were 9 in there for a few hours and went from 5 to 1.5 in CL from last night to tonight.
    So, 3 answers, 50, 70 and 80.
    I definitely don't want to go too high. Thanks for your help.
    Matt
    Feb 2011
    Petaluma, Ca
    665
    Quote Originally Posted by mgmoore7 View Post
    Sounds like 66.6 to me. With an auto cover I keep 50 / 60, its closed most of the time and it blocks nearly all the light.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    May 2015
    Land O Lakes, FL
    527
    Quote Originally Posted by bobby1017 View Post
    Don't like that number much at all.
    Matt
    Richard320's Avatar
    Jan 2010
    19,051
    Well, actually, I missed the part about screened, so 80 is probably too high, even with a SWG.
    May 2015
    Land O Lakes, FL
    527
    Ok, i had put more cya in the skimmer but pulled it. It is at 60 now and will leave ir there for now.
    Matt
    30,431
    I think you will find yourself right in the sweet spot.
    May 2015
    Land O Lakes, FL
    527
    Ok, thanks
    Matt
