Results 1 to 7 of 7
Thread: Heater plug stripped
    May 2014
    Mid-Michigan
    30
    I was opening the pool last weekend and the heater plugs and opening are badly rusted and one completely stripped. Right now I am unable to run my system because it is not plugged. I would like to just get through the summer with the heater and replace next spring. My buddy tried to weld it closed but had a problem with the welder. So now I am think to add a bunch of JB Weld to seal that opening off. Any other suggestions before I go ahead and go this route? Not sure if there are other plugs that I could use that would hold up to the pressure. Any help would be appreciated.
    Steve
    Steve
    20x40 35k gal, IG vinyl, Hayward sand filter, New Pentair Superflo vs pump, 220 btu heater, aquaclean EZ robot
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Heater plug stripped
    Is this the type of plug you're referring to? Raypak Drain Plug (006721f) - INYOPools.com
    Plastic or brass with T shut off?
    If you can get a Visegrip type wrench on that style of plug, you can replace it.
    Isolated Spa - 345 Gallons
    May 2014
    Mid-Michigan
    30
    There is nothing left on the inside to be able to screw into. Maybe a rubber plug that twist from the outside?
    Steve
    Feb 2014
    Central Minnesota
    5,080
    Wouldn't trust a rubber plug then. Best of doing some JB Weld to close it off completely. Think they have a high temp version.
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    What heater do you have so we can better assess the issue for you.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Is there room to drill and tap it to the next larger size?
    May 2014
    Mid-Michigan
    30
    I probably could have drill and tapped it, but I was in a yank and don't really have that skill set. My buddy was able to weld enough to get the bolt in and I put JB weld all over the place. It is holding just fine right now, but might still need to figure out a more permanent fix. Again, just trying to get through the summer and will replace the heater next year. Thanks for the ideas everyone!
    Steve
    Steve
