Results 1 to 10 of 10
Thread: What is the best sealant for fiberglass steps to surrounding concrete?
    Jan 2015
    Northeast Georgia
    19
    I need to reseal my fiberglass step insert to the surrounding concrete. What is the best sealant to use for this job?
    Philip
    20.3K gal, IG vinyl, Hayward S244T sand, 1HP Hayward SP2607X10 pump, Saline Generating Systems "Breeze 540" SWCG, circa 2000, TF100/SpeedStir, 5 AquaSol AQ48 solar panels, Intermatic PF1103T 1.5/3HP Timer, Kreepy Krauly Classic
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: What is the best sealant for fiberglass steps to surrounding concrete?
    I am not sure if there is a specific product used by pool builders to do this, if there is please let us know
    I would use 3m 5200, "3M 5200 is a single part sealant that cures to form a firm, rubbery waterproof seal. When fully cured, this high strength marine adhesive remains flexible and suitable for use where shock, vibration, shrinking or swelling are concerns."
    3M 5200 Marine Sealant
    It is permanent, so make sure you don't ever want it to come off
    Jan 2015
    Northeast Georgia
    19
    Thanks, cowboycasey.
    That is some serious looking stuff! I'll see what I can find out from pool builders and will report back here.
    Philip
    Jan 2015
    Northeast Georgia
    19
    Quote Originally Posted by cozybuilder View Post
    Philip
    A pool builder I contacted recommended filling any voids with play sand up to a half-inch from the top, then filling this half-inch void with self leveling concrete sealant available from Home Depot.
    I'll give this method a try and report back here when finished.
    Philip
    pookiesunshine's Avatar
    May 2016
    Cincinnati, OH
    433
    Philip
    This must be a top, horizontal seam then. I was thinking it might be between the bottom of the coping and top of the steps which would require something different from self leveling.
    30000 gal inground vinyl liner;sand filter w/glass media, nuvo uv, TF-100 test kit; 25 years on Baquacil, converted to TFP chlorine in 2016
    Jan 2015
    Northeast Georgia
    19
    Quote Originally Posted by pookiesunshine View Post
    You're exactly right, pookiesunshine. I'm referring to the top, horizontal outside seam where the outside perimeter (3 sides) of the step insert joins the surrounding concrete.
    I'll post some before and after photos.
    I do recall this same builder used silicone sealant to seal the underwater vertical seam where the step insert joins 3 pieces of trim that separate the step insert from the vinyl liner.
    Philip
    Philip
    To clarify, vertical seam as in on the wall of the pool. Technically, at the step insert, there are 2 vertical (up and down) seams, and one horizontal (side to side) seam on the vertical pool wall.
    Philip
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    That sounds like an expansion joint and it should be filled with sand and/or foam backer rod to about 3/8-1/2" depth. Then the joint should be filled with self leveling polyurethane caulk. My PB uses Sikaflex brand.
    Jan 2015
    Northeast Georgia
    19
    Smile Re: What is the best sealant for fiberglass steps to surrounding concrete?
    Quote Originally Posted by pooldv View Post
    Hi pooldv,
    This is a tardy follow up, but that is basically what I did. After removing what was left of the old sealant, I filled the void between the step insert and the concrete with sand (this seam varied in width and depth, and there was no expansion joint material that I could see). I then used a toothbrush to achieve the correct depth with the sand. Sikaflex brand is the one I used. It is self-leveling and for use in horizontal joints only, but I experimented with this stuff and found that by holding the nozzle against the steps during application, it worked great. The stuff exits the tube in a semi-liquid state and sticks where it is applied, but after a minute or two, it goes into a more liquid state and the "self-leveling" feature really kicks in. This created a really nice cove joint between the vertical pool step and the horizontal concrete.
    I stuck around to watch the stuff do its magic. I had some low spots develop where more material was needed; adding more material was easy to do because nothing had set up yet. I was also able to clean up any mistakes and some overflow by wiping it up with paper towels before it started setting up.
    Thanks everyone for the input!
    Philip
    Oct 2016
    Phoenix
    181
    I use Sikaflex too in all kinds of horizontal seams like concrete driveways and patios. I go so far as to wait until winter when the gaps are the widest due to the cold. As mentioned by others, I fill with sand or backer foam first and then apply and let it level. Come summer, when the concrete expands, it compresses a little but I keep it thin enough so that is not an issue. If I seal in the summer, the shrinking concrete in the winter tends to pull the caulk apart in a season or two.
    Dave in Phoenix, AZ, USA
    12,000 gallon IG (5' max depth) , Pebble-tec,
    Hayward SP2303 Maxflo 1.65 HP, Triton TR60 sand filter, 1 skimmer, Pool Devil skimmer, 3 returns, 1 aerator port, Navigator suction-side sweep, Hayward valve actuator, Rainbird sprinkler timer used for valve automation and chlorine injection. Softened water used for makeup.
    DFW, TX
    24,497
    Hi pooldv,
    Philip
    Nice work! Looks great. Thanks for following up.
