Results 1 to 7 of 7
Thread: Filter gauge needle in wrong place
    Jul 2015
    Cape May Court House, NJ
    121
    Just had my pool opened yesterday and I noticed the filter gauge needle didn't move when I turned on the pump. It looks to me like the needle is on the wrong side of the pin, so the pin seems to be blocking the needle. Is this fixable or do I need to order and install a new gauge?
    22K 16'x40' inground fiberglass pool, Hayward Pro Series High Rate Sand filter, Hayward dual speed 2 hp Super II Pump, Hayward AquaRite SWG, Raypak 400K btu propane heater, Dolphin Supreme M400 cleaning robot, CoverPool auto cover. Also stand-alone Sundance Hawthorne 430 gallon hot tub.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: Filter gauge needle in wrong place
    I'd just get a new one. The ones at tftestkits.net are very nice and not expensive at all. I get nothing out of suggesting them, I just prefer them myself.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    That generally happens when the valves freezes or is otherwise junk. No way to repair with any confidence of accuracy. I second the TFT gauge per personal preference.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Isaac-1's Avatar
    SW Louisiana
    6,711
    A 3rd for the TFT gauge, all the major brand pool gauges are junk that die after a couple of years, invest in a quality gauge and it will last you a long time. I personally don't have one of the TFT gauges, but that is only because I already had a quality gauge before they started selling them.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    It's gauge time. If you can change a light bulb, you can change a gauge. You'll need a wrench and some teflon tape, but the actual mechanics are pretty much identical.
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    You must have gotten water in the gauge's bourdon tube last summer which did not drain when you winterized. The water froze and stretched the tube which caused the needle to bottom out on the stop pin on the high pressure side. There is no way to fix it.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    Jul 2015
    121
    Ok, I'll order a new gauge first thing tomorrow. Thanks, everyone!
