Thread: How do I turn on my heater
    May 2016
    Tulsa, OK
    3
    Hi all, new pool owner here! When we first moved in to our new house last month, I had a pool company guy over to show me how to clean/vacuum the pool and check chemicals. He also showed me how to turn on this gas (original) heater to the pool and in ground spa, which is separated from the pool by about 5 feet, but share common filter/pump. I took pretty good notes, but apparently not the part about the heater! Its so old I can't even see what brand it is. I have attached some pictures here:
    25,000 gallon in ground pool
    85x72 in ground spa, separated from pool by 5 feet.
    May 2016
    Tulsa, OK
    3
    Re: How do I turn on my heater
    Adding pic of gas line to heater. Do I need to turn this green valve horizontally to turn on gas?
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Yes, that valve is currently in the OFF position, i.e. the handles are perpendicular to the gas line. It should turn only 90 degrees, i.e. a quarter turn valve and the handles will end up parallel to the gas line and will then be in the OPEN position.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    You have an older Raypak 2100 unit. Turn the gas valve on, green handle by the side of your house, then turn the dial all the way to the right, then flip the on/off switch on the front of the heater. Then hopefully it will light and work.
    Paul
    http://www.gastekservice.com If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - http://www.youtube.com/c/Gastekservices
    May 2016
    Tulsa, OK
    3
    Awesome, thank you!
