Thread: Auto Fill Shutoff Valve Identification
    Jun 2015
    Montgomery, TX
    24
    Afternoon,
    Quick question. I am going to start the SLAM procedure within the next 2 days but need to replace some of my water as my CYA is at 80. I understand how much water I need to replace by checking the pool school calculator.
    I have a floater value which regulates the addition of water. In order to shut this off I need to shut off the water valve. Is the picture below my shutoff valve for the water?
    Once I have replaced the correct gallons of water and gotten my CYA level to around 40-50 I will then refill and start the SLAM procedure.
    Thanks forthe assistant on identifying the water shutoff valve.
    39,460 Gallon Gunite outdoor in-ground, Pebble Tec, 37' W x 38'6" L, Attached Spa and slide, Pentair Clean and Clear Plus Cartridge Filter, 2- Pentair Sta Rite Variable speed pumps, Pentair Sta Rite 3.0 hp Max E Pro, Paramount PCC 2000 In Floor Cleaning and Circulation system, Rainbow Chlorinator, Paramount O3 Ozonator and Trident UV
    38,371
    Re: Auto Fill Shutoff Valve Identification
    Maybe ... turn it off and see if the auto-fill stops adding water
    Jun 2015
    Montgomery, TX
    24
    Confirmed. Yes it is. Thanks for the heads up!
    38,371
