Thread: AquaComfort 125 Electric Heat Pump BTU?
    FattyLumpkin's Avatar
    May 2016
    Massachusetts
    188
    Hi - I've searched the manuals and done a cursory search online, but can't seem to locate the BTUs my heat pump generates. I'm trying to calculate 1) the cost per kwH to run this thing, and 2) what my expectations should be for heating my pool from 65-ish to 80 for this weekend. The temps up here in NE are supposed to get into the 80s moving into the weekend (near 90 tomorrow), so I figured I'd fire it up and watch the dollar bills literally evaporate -- I just wanted to get a baseline energy usage and whether a 15 degree gain in 3 days of 80+ degree warmth was even reasonable...
    Any help appreciated - thanks all!
    / 24k Gal, 18x36 Freeform IG Vinyl Saltwater / Sta-Rite MPRA6E-205L 1HP Pump / Sta-Rite System:3 Cartridge Filter / IC-40 SWCG / Dolphin Nautilus Cleaner / TF-100 Test Kit w/ SpeedStir / Taylor K-1766 Salt Test /
    Useful Links: Recommended Levels / SLAM / FC/CYA Chart / Test Kits Compared / Edit Your Signature
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: AquaComfort 125 Electric Heat Pump BTU?
    Hmmm, the manual sure does not say anything http://swimmor.com/manuals/AquaComfo...eat%20Pump.pdf
    My guess from the name is it is 125 BTU
    The last person asking had to call them aqua heat LS
    I hope this helps
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,776
    Under ideal conditions you will get about 125kBTU out of your heat pump. They claim to have a COP of 6 so for every watt you put in of electricity you will get 6 times the amount back in heat.
    1000w = 3412 BTU/hr
    3412*6= 20472
    125000/20472= 6.1
    So you will use roughly 6.1 kW/hr to run the heat pump. Which fits with the recommended breaker size for that unit. If your rates are like mine @ $0.22 kW/hr after delivery charges it will cost you about $1.20 an hour to run your heat pump.
    In a perfect world 1 BTU heats 1 pound of water 1 degree. So water weighs 8.34 lbs/gal and you have 21k gallons.
    8.34*21000= 175140 lbs
    175140/125000= 1.4 hr / degree
    15/1.4 = 10.7 hours just to heat the water in your pool
    Once you add the mass of the pool walls and evaporative loss ( you have the solar cover on right ) Time to heat everything up takes a lil longer. And as outdoor temps drop the COP of the heat pump drops too. Aquacomfort claims to have High COP values across a broad temp range. What you will get real world you can only figure out by doing what you said and turning it on. Your cost may vary but with consistent use of a solar cover when you aren't using the pool you should expect to see a bill between 300-600 for the entire season. That's with keeping the water in the mid to upper 80s.
    Aqua comfort only sells equipment thru authorized dealer/installers. You cant purchase a unit directly or online.
    Oops my math was wrong its 1.4*15 = 21 hours to heat the water in your pool 15 degrees
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    May 2016
    Massachusetts
    188
    Awesome, thanks so much for the responses!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Put an 8 mil solar cover on that pool and keep the heat you are buying in the pool.
    May 2016
    Massachusetts
    188
    Thanks pooldv. I have one, but it fits horribly. I use it nightly nonetheless... Going to get a huge one and cut it down to custom fit.
