Results 1 to 7 of 7
Thread: Algicide
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Algicide
    So I just bought some algicide for the pool because I haven't treated the water when I opened the pool. I'm in the middle of a slam right now. The ingrediants have 50% Dimethyl Benzyl Ammonium chloride and 50% other ingredients. Is this something i can put in now to help kill the algea or should I wait?
    40x18 Lazy L Rectangle
    29500gal IG w/ vinyl liner
    HAYWARD S244T 300lb sand filter
    Hayward Super Pump 1 1/2hp
    38,262
    Re: Algicide
    Algaecide does not really kill algae, it is more of a preventative ... stick with bleach and the SLAM process. We do not recommend adding unnecessary chemicals.
    What are your current test results?
    Jun 2014
    15,056
    Re: Algicide
    If you are currently doing a SLAM, then do not add any algaecide. The bleach will do everything you need it to as long as your FC and CYA ratios are correct.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Algicide
    Be aware that the algaecide you have will probably cause foaming in the water when you add it.
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Re: Algicide
    I'm about to add DE to the filter and do a set of test results. I got the algicide because when I was reading the pool openings it said to treat with algicide. Maybe I read it wrong. I'll post back in a bit with the test results.
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Re: Algicide
    FC 14
    PH was 7.2 at beginning of slam
    CH 50
    TA 50
    CYA assuming 20 (was 0 added 5lbs stabilizer)
    Water is still cloudy blue in deep end and cant see drain yet. Ive been brushing atleast 2x a day. Vacuumed yesterday
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Re: Algicide
    Perhaps you read about newly built plaster pools- they often suggest algaecides then as a preventative measure while the plaster cures and the pool chemicals and test levels still being tweaked.
