Thread: Debri on bottom of pool.
    Apr 2016
    mass
    6
    Hi All,
    I just purchased a house with an in-ground pool and trying my best to revive it. I have not started the pump or filter yet which I hope to do this weekend. I noticed what may be DE or other fine material on the bottom in the deep end. My question is should I vac to drain until I get the material up or just run it through my DE filter. I would rather not waste all the water if possible as its pricey in my area.
    I attached some pictures but its hard to see.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Debri on bottom of pool.
    Welcome to TFP
    Vac to waist for all that debris then start your SLAM
    Do you have your test kit yet, that will be your best weapon to clear that pool along with bleach
    Apr 2016
    mass
    6
    That worked thank you.
    New owner of a house with an In-Ground gunite pool built in 1978 without any upgrades. It is a 17' x 34' 22,500 gallon pool located in New England (home of the NE Patriots) .
