Results 1 to 7 of 7
Thread: Skimmers with 2" or even 2.5" connections? Wall fittings that size as well?
    MitchRyan912's Avatar
    Jul 2015
    Madison, WI
    333
    We may be in position to redo the fittings and skimmer in our vinyl liner pool, as we are putting in a new liner along with everything else we are doing (pump, heater, new MPV on our filter, & pipes - all in a new pad location).. As such we will be putting in 2.5" pipe instead of the 2" we were planning to install.
    if we are able to do so, is it worthwhile to go ahead and upsize the fittings and /or skimmer?
    2016 total pool rebuild thread: here. Pool: 26,000 gal IG vinyl liner (20'x40') in Madison, WI. Gear: ​Superflo VS, Triton TR-60 filter, 2" hi-flow MPV, & Raypak 266A heater. Testing: Taylor K-2006C. Manual chems: 12.5% NaClO liquid, granular CYA, baking soda, 31.25% muriatic acid.
    30,403
    Re: Skimmers with 2" or even 2.5" connections? Wall fittings that size as well?
    Not really. For that matter, the 2.5" pipe will yield little value in a 26k pool.
    The important things to remember is to match pump and filter and then match that to the size of your pool.
    2" pipe is gracious plenty for a 1 or 1.5 HP 2-speed pump and 30" filter on a pool that size.
    Jul 2015
    Madison, WI
    333
    Wouldn't we be able to move more water and reduce pump run time with 2.5" pipe?
    We're buying a Superflo VS and a high-flow MPV for the TR-60 we own. We're going to see if the TR-60 even works (it's at least 30 years old, but I put a new hub & laterals in last year). If it doesn't, the TR-60 will be plumbed in a way that we could drop in a TR-100 later. We were about to pull the trigger on buying a new TR-100, but decided the new valve route would be a money saver for the time being.
    Jul 2015
    Madison, WI
    333
    The longest suction run is about 53' (deep end low wall vacuum).
    The shortest suction run is about 40' (skimmer).
    The return is about 27' long.
    Would it make any sense to just run 2.5" pipe on the suction lines? How about just the long vacuum line?
    mas985's Avatar
    Pleasanton, CA
    11,737
    You will get a little higher flow rate or lower RPM for the same flow rate with the larger pipe. Also, the suction would be less in the pump basket and thus less likely to suck in air. But would you be installing 2.5" poly?
    BTW, for the same flow rate, the change in RPM would probably be around 5% and 10% in energy savings. But you would have to reduce the RPM to achieve those savings.
    Mark
    Jul 2015
    Madison, WI
    333
    I think we are leaning towards leaving it as is, with 2" poly. Now to consider if it is worth a little more digging to add a second return, since we are messing with the liner...
    Jul 2015
    Madison, WI
    333
    I had assumed there were larger wall fittings available, and since it doesn't look like there are, I'll stick with the 2" pipe, so there's only one adaption from 1.5" to 2", rather than 1.5" to 2" to 2.5".
