Results 1 to 7 of 7
Thread: Liquidator users
    Dec 2015
    Newington, Connecticut
    113
    Liquidator users
    How many gallons of bleach are everyone putting into the liquidator at a time. I've been maintaining about 4 inches.
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Liquidator users
    Sorry no one has seen this yet, busy season
    maybe this will help
    So I think I want a Liquidator...
    Apr 2013
    Sacramento, CA
    2,769
    5 to 6 gallons I didn't want it to get low in case I got busy.
    JayG's Avatar
    Aug 2015
    Harrison, NY
    203
    Andrew,
    How is the liquidator working with your VS pump? So far so good? Just curious because I had come to believe that the two were often not a good match. But I see that gwegan also uses a VS pump. I went with the Stenner because I was getting a VS pump. I'm always trying to learn.
    Thanks!
    Jay--Metro NYC
    35K gal, in-ground, free-form, pebble finish, 2 skimmers, 3 returns, autofill. No spa, no features. Partial shade.
    Pentair C&C cartridge filter (400 sq in), Pentair VS pump, Pentair 140 btu heat pump, Triton Plus Robo-cleaner; Stenner with 55 gal bleach cistern. TFT 100 test kit.
    Dec 2015
    113
    I use my vs pump at one fixed speed at all time so it works pretty good. I'm trying to work out some quirks as far as flow goes. Need to put the upgraded fittings back on. Had an issue with bubbles that I finally figured out. Made a shade box out of pallet wood. So now it's not in the sun. Just have to get the flow rate up.
    Thanks gwegan. Do you have the liquidator supply tied into the strainer drain or did you use the supplied drilled fitting. I'm trying to figure out if the suction is the same from either location.
    Apr 2013
    Sacramento, CA
    2,769
    I have a steinner pump now. I need to change my signature. I would say that a liquidator is not a good match with a vs pump on low speeds or with a solar system. It did not work for me.
    Ellington, CT
    262
    When I setup mine theispast Sunday I filled with 5.5 gallons of 12.5 % chlorine. On season start up I manually dose the pool to bring FC up to my target and then set the flow rate, using a pinch valve on the Liquidator to a level that will replace the daily lose. This of course take a few days to dial it in, but I know after a couple of years that the pinch valve will need to be somewhere between 3 to 4 on the pinch valve setting scale. I usually refill the Liquidator with three or for gallons once the chlorine level reaches 2 inches from the bottom of the tank. So, under normal circumstances I have 2 to five gallons in the Liquidator. If I plan on being away longer than a week, then I will fill it up to the max level stated in the Liquidator operating manual.
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
