Thread: Black Algae & Pump Run Time
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    I battle black algae every year at the beginning of the pool season it seems like with my pebble surface (probably due to cold weather FC neglect). I have my FC elevated and I am performing manual brushing.
    I normally run high speed for about 3 hours, and then low speed anywhere from 5-8 hours to maintain a TFP salt water recommend FC level in the early evening. Should I be increasing my low speed pump time to promote greater water flow over the black algae areas throughout the day? Or does pump run time not really matter as long as I'm maintaining an elevated FC all day?
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Black Algae & Pump Run Time
    Brush, brush, brush! Seriously you can't brush enough. I'm in a similar situation. I can't brush enough. Once you get it clean, no black spots visible, always maintain your free chlorine level on the high side. And brush!
    Brushing will promote mixing. No need to increase pump run time, unless you've got a SWCG and need the additional time to make more chlorine.
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Quote Originally Posted by bobodaclown View Post
    I do have a SWG but I can maintain an good FC level with a lower pump run time and higher output.
    Apr 2011
    Murrieta, CA
    2,360
    You're using a stainless steel brush not nylon correct? Maintain on high side based on CYA level. Also review this: Pool School - Black Algae
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Oh yeah. I have both a steel brush attachment for my pole and a smaller steel brush attachment which I throw on some goggles and scrub by hand.
    Apr 2011
    Murrieta, CA
    2,360
    I feel your pain.
