Results 1 to 7 of 7
Thread: 1 1/2 inch return line valve question
    May 2016
    woodland washington
    9
    Hi everyone,
    Need some clarity on my pools 1 1/2 inch return line valve just out from the filter. Currently it works fine, it is a two position manual valve controlling either the 2 returns on the side of the pool or the two returns in the stairwell. Do they make a valve that would supply water as stated above and also have a position to supply both side and stair returns at the same time.
    Thanks
    18x36 Rectangle, estimated 27,000 gal, new vinyl 2015. Pool was built in 1994
    Hayward Pro Series High Rate Sand Filter, Model No. S-244T, 62 GPM Filtration and Backwash Design Flow
    Hayward Max-Flo Pump ( 1-hp ) 115/230 SP 2807X10
    38,271
    Re: 1 1/2 inch return line valve question
    I am not clear on what you have now, but a 3-way valve (like the Jandy Neverlube) would do what you are asking.
    Maybe that is what you already have? Post a picture.
    May 2016
    woodland washington
    9
    38,271
    Well, I have never seen a valve like that. It does not appear that you can run both sides. Can you turn the handle to be toward the camera? Would that run both?
    A typical pool valve should fit there ...
    May 2016
    woodland washington
    9
    Yes the picture does not show all the factory markings. As it is position now, it is pointed at port 2 (stairs) return and i can rotate it 180 to port 1 (side jets). The valve can also be turned to the off position (see Picture). The off position works on in two locations, position in the picture and on the back side of the picture marked off. I do believe it is an Hayward Valve.
    Thanks for you input. I checked online and looks like the Jandy Valve is what i would need. Now i just need to figure out which model number
    38,271
    If you have 1.5" pipe, get the 1.5/2 size valve. If you have 2" pipe, get the 2/2.5 size valve
    May 2016
    woodland washington
    9
    Thanks for your help. TFP is the greatest
