Results 1 to 11 of 11
Thread: Adding liquid chlorine daily.
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Hello. I live in Central Florida. The heat is on now. Everyday I am adding an average of 3 to 6 cups of liquid chlorine (from the pool store) depending if the day before was sunny all day or cloudy.
    I am trying to kept my FC close to what my CYA tell me using the table here.
    The current reading today using my Taylor K-2006c was as follow:
    FC 9.5 (yesterday was 8, I added 6 cups of liquid chlorine. Maybe I added to much)
    CC 0
    TA 80
    CH 240
    CYA 60
    Usually I lost one or two ppm of FC. Of course, I am adding daily certain amount of cups depending of the test result.
    Question: Is this is a (give or take) normal daily loss of FC?
    By following the instructions here and reading your recommendation to others I now have a crystal clear sparkling pool but can't let the FC to go below the recommended amount or I may see a little patch of algae. I am brushing every two days or so. Not because of algae problems. I just want to kept it clean.
    I don't think I need to slam my pool but would like your opinion about it.
    Thank you for you help and information.
    15K gallons, Plaster, Taylor K-2006C & TF-100, DE, non SWG, Hayward TriStar VS variable pump
    38,546
    Re: Adding liquid chlorine daily.
    "Normal" if there is such a thing is roughly 2-4ppm FC loss per day.
    Aug 2014
    Northern IL
    4,615
    No. 1-2ppm loss per day is perfect! Most people would be very jealous... Good job keeping up with your testing! Is the pH good also?
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Thank you for the information.
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Quote Originally Posted by MarianParoo View Post
    Thank you. The PH is a little hard to maintain within the recommended level. Average is close to 7.6 or 7.8. But if I don't add acid at least 2 cups twice a week it jump up to 8. I think the reason is because of the liquid chlorine I add daily. TA is always 80. Hardly go to 70.
    Aug 2014
    Northern IL
    4,615
    Do you have a vinyl or plaster pool?
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Shame on me, I am not sure.
    We bought this house with the pool that was build back on 1990. The only record that we got was from a pool store close to the house. the previous owner(s) was doing business with them. They told me that their records shows it is a Marcite/Gunite pool. What I can only tell is that the surface is kind of "rough" and so are the walls. Comfortable rough and have real tiles on the top. I know that does not say much.
    Thank you!
    Jul 2015
    Tempe, AZ
    194
    Try working your TA down to 70 or 60 and see if your pH rise slows. When I did this, my pool went from using about the same amount of MA as you down to about a cup a week with a pH that stays right around 7.5 to 7.6 with very little upward pressure. From reading here, it seems that some pools prefer a slightly lower TA for pH stability.
    John - 16,000 gallon | in ground | pebble | Triton II sand filter | TF100 | speedstir | Hayward Phoenix 2x
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Then you have a plaster pool! You can add that to your sig if you like
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jun 2011
    Long Beach, CA
    2,790
    It is a plaster pool. There are many types of surfaces that get incorporated in to a plaster pool. Plaster pools have a surface that is cement based.
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    I will do so. The Pool Math mention "To lower TA you reduce pH to 7.0-7.2 with acid and then aerate to increase pH.
    This is the way I will do it. Thank you!
    Thank you!. After 2.5 years wondering now I know!!
    Added to the signature
    Thank you. Now I know.
