Thread: Tim
    May 2016
    Pasadena
    4
    Tim
    I am currently using baquacil to treat my pool. I am converting to salt water water. I need to know how to convert the water over after the system is on line. I don't know what chemicals use to remove the Baquacil in the pool? I know Baquacil really well. But I am in a new world with this conversion & salt ? Please Help.
    Above ground 15' x 30' Oval 42" 10,000 gal / Baquacil
    2 Spd 2 HP Pro line 150 Sq ft. Cartridge Filter
    Jun 2014
    15,103
    Re: Tim
    Hello and welcome to TFP! You need to follow the TFP Pool School - Convert Your Baqua Pool to Chlorine page. It's all about bleach. Follow these instructions to convert from baqua to chlorine, then once it's all clear we can help you one step further to salt and your SWG. Nice to have you with us.
    Husky25's Avatar
    Jun 2015
    "East of the River" CT
    452
    Re: Tim
    Don't put the SWG system on-line until you convert from Baquacil to regular Chlorine. Check out the threads in the Baquacil section. A few of us have documented our experience and you can learn a lot by lurking (though don't be afraid to ask your questions).
    First steps, though, are to get one of the recommended test kits and about a dozen or so cases of bleach. Then follow the ateps in TS's post. If you are diligent, you can get through the heavy lifting in days as opposed to weeks.
    Chris
    Outdoor in-ground 18' x 36' rectangle w/ vinyl liner. 2 returns, 2 drains, single pool side skimmer, ladder, diving board, LED multi-color light, Pentair Cristal-Flo II Sand Filter, Sta-Rite Super Max 3/4 HP Pump, AquaCal R410A heater, SpeedStir, TF-100. Baquacil Conversion of former pool - June 2015, SLAM How-to, Chlorine/CYA Chart
    Aug 2010
    Dallas, TX
    4,052
    Re: Tim
    And a second to-be technicolor pool! Two conversions starting the same day! I can't wait for pictures!
