Thread: Second time "opening" need refresher
    Jun 2014
    Bismarck, North Dakota
    28
    Hello friends,
    This is my second time opening pool. Last summer I started with green water and had to work hard to clean it. This year I decided to drain and start fresh. My numbers are: FC 0 CC 0 PH so low color not on tester, TA 140, CH 110, CYA 0
    Last year I learned that if CYA gets too high, the only way to fix is to drain, so I am very scared to add stabilizer.
    I put numbers in pool math and all I have added so far is: 59 oz. bleach.
    Do I need to add PH up and stabilizer?
    Thanks in advance!
    8600 gal/ag/Richwood Round 18 x52 swinn'play pool, Aquamaster sand filter, Waterway pump, install 6/25/14
    Jun 2014
    15,093
    Re: Second time "opening" need refresher
    Welcome back again! Well, here's the basics to get started:
    - You do need stabilizer (CYA). Use the Poolmath calculator and aim for a low CYA target of 30. That's all.
    - One day 1, just keep the FC at about 3 ppm with bleach. Once the stabilizer is in the pool, then increase FC to about 5 ppm.
    - PH needs to be about 7.6. Use either soda ash or borax to raise it.
    Once you get those three items stabilized, we can worry about TA and anything else.
    Aug 2014
    Northern IL
    4,615
    Raise pH right away! Use 20 Mule Team borax as that won't raise your TA too much. Is there an active ingredient on your pH up? MAYBE you could use it... Let us know.
    Add enough CYA to get you from 0 to 20. A reading of zero can be zero or 15-25 depending on your testkit. What are you using?
    Jun 2014
    28
    Quote Originally Posted by Texas Splash View Post
    Thanks Pat!
    Jun 2014
    28
    Hey Pat,
    Here is where I am today:
    FC 3
    CC 0
    PH 7.9-8
    TA 125
    CH 125
    CYA 35
    I used the pool math and it says to lower PH a bit...Should I? I know in the past I have been told anything in the 7's is ok. Will it come down a bit on it's own?
    Pool math says raise CH a bit??? I have never had to do that in the past....
    Thanks for your help!!!!
    Trudy
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Quote Originally Posted by Trudy.Riehl View Post
    Hey Pat,
    FC 3
    CC 0
    PH 7.9-8
    TA 125
    CH 125
    CYA 35
    Trudy
    pH will only rise on its own, so you do need to add some acid.
    And you don't need CH in a vinyl pool. Check that poolmath didn't reset itself on you. Go to the last row and select vinyl/bleach/TFP for suggested levels. Also ensure the volume at the top didn't reset to the default 10,000 gallons. Then just use the Now CH as the Target CH. Done. No CH needed. Same thing for TA.
