Results 1 to 15 of 15
Thread: Do I fix CYA or PH and TA first?
    Aug 2013
    Dallas, Texas
    85
    Question Do I fix CYA or PH and TA first?
    Hey Guys,
    I'm having issues with my PH again, as well as CYA of 0 and slightly raised TA. I understand lowering PH will lower TA however do I fix the PH or CYA first as I understand increase CYA has an affect on PH.
    FC: 3.5
    CC: 0.5
    TA: 140
    CH: 340
    CYA: 0
    Thanks
    17500 Gallons, IG, Plaster, DE Filter, Built 1997, No Spa, Polaris 280
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Re: Do I fix CYA or PH and TA first?
    Fix the CYA first,
    CYA is acid and acid of any sort will lower the pH.
    TA is the very last thing you need to do. All others come before it.
    Divin Dave,
    Aug 2013
    Dallas, Texas
    85
    OK just put a sock full of CYA - now wait a few days....
    Is it still safe to swim while doing this?
    38,540
    Yes, safe to swim with the CYA dissolving. If you are swimming, I might prefer it be in the skimmer so the cloudiness is not in the pool.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    How high is your pH? Your TA is pretty high, so your pH will naturally rise pretty fast and may cancel the pH drop the CYA causes.
    You can swim safely if the pH is between 7.2 and 7.8. Higher or lower may lead to dry itchy skin and burning eyes. So you may wish to adjust pH to at least 7.5 if you're at the top end of the scale. Or off the scale without knowing it.
    TA is the last parameter you worry about.
    Aug 2013
    Dallas, Texas
    85
    No real idea what PH is as my test kit only test to 8, I believe it is a lot high. Do you just putting in some M Acid in addition to the stabilizer (which has dissolved from the sock).
    Richard320's Avatar
    Jan 2010
    19,074
    Quote Originally Posted by onedah View Post
    If you're at the top of the scale, enter that number for the pH along with the TA reading and add the dose of acid poolmath figures for you. Let it mix well and test again. Just keep doing that until the color moves. You might hit it or you might be high still, but you'll be on the scale and the last application should do it.
    Aug 2013
    Dallas, Texas
    85
    I did as poolmath suggest - levels of what I have tested are:
    FC: 8
    CC: 0.5
    PH: 7.2
    TA: 100
    CH: Not Tested
    CYA: Not Tested
    I will test CYA in a few days and keep an eye on the PH - I am supprised that I managed to get PH to 7.2 already and TA dropped so quick.
    Aug 2013
    Dallas, Texas
    85
    I tested again this morning and no FC loss so good on that front however PH started to rise again - its at 7.5 since last night.
    We did have rain most of the night but would that effort the reading? Should I look at adding some more MA?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    7.5 is fine. Just don't let it go above 7.8.
    It's possible the aeration of the rain raised it, or 7.5 is its happy zone.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Aug 2013
    Dallas, Texas
    85
    PH hit 7.8 today - I'm gonna add some MA and see how it goes.
    My FC level is consistent so no worries that end. need to re test CYA.
    Aug 2013
    Dallas, Texas
    85
    My PH is on the rise again - hit top of my kit 8.0 - I have added more MA per poolmath, we had rain again in Dallas yesterday but could it be messing with my PH that much?
    Also tested my CYA and got a reading of ~70, I had a CYA of 0 6 days back and added stabilizer, actually less then poolmath however CYA has over shot.
    I'm going to wait and test CYA again tomorrow before I empty some of the water.
    Any suggestions in the meanwhile?
    Richard320's Avatar
    Jan 2010
    19,074
    Rain can seriously aerate the pool and drive pH up. Sounds normal.
    Aug 2013
    Dallas, Texas
    85
    My PH seems to still be rising but a lot slower than before - as suggested the rain hasn't help.
    I did measure my CYA again and this time I got a reading of 50, so it appears to have gone down from 70, understand this test can be very subjective, however can rain also play a big part in CYA i.e. the amount of rain we have had in the past week could help reduce CYA just like replacing % of the water with new water?
    30,432
    One day I will have a neon electric flashing sign on the forum....."Rainwater has very little effect on your pool water" It is one of the hardest to shake "pool myths" I think perpetuated by pool stores so they can sell you some anti-rain gizmo's.
    That said, if you have a gullywasher that flows into the pool from the surroundings, well, there is almost no bigger mess!!
