Results 1 to 8 of 8
Thread: Post-Slam/OCLT: FC Loss
    Sep 2014
    Elgin, IL
    23
    Hi. I had to close my pool early last fall and it was a bit green when I opened. I did a slam and passed an OCLT for two nights in a row, the second OCLT passed this morning. The water is sparkling. I decided to let my FC drift down. Here are my current numbers:
    FC 14
    CC. 0
    PH ? Was 7.2 before slam
    TA 130 (will work on this later)
    CH 170 (need to raise for my heater later)
    CYA just under 40
    This morning the FC was 18 with 0 loss overnight. I lost 4ppm during the day today. I plan on testing FC/CC again after dark.
    I am wondering if FC can fall that fast or if I have an issue. Any advice?
    Aug 2014
    Northern IL
    4,615
    Re: Post-Slam/OCLT: FC Loss
    Gee. I really am not sure... Anyone?
    Sep 2014
    Elgin, IL
    23
    Retested after dark. fC still 14. Still wondering if I should be worried.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    A loss of 4 sounds reasonable with under 40 CYA.
    The higher the FC, the faster it drops. It's not a fixed parts per million, but a percentage. So the higher the starting point, the more you lose. Part of the reason we don't push for a higher FC level during the SLAM -- so much gets lost to the sun at higher levels.
    Trust your results. You ran the OCLT twice and it was fine. You've ruled out organics, so it has to be sunlight. I know somewhere there's a graph. I should go hunt for it.
    Update: Second and third graphs should put your mind at ease. Pool Water Chemistry
    Sep 2014
    Elgin, IL
    23
    I am in big trouble. Please help. First OCLT passed Saturday/Sunday. The second on Sunday/Monday.
    Tuesday's results (FC was 14 after dark Monday night) CYA <40
    6:30am FC was at 10 CC 0 (an hour after sunrise: Out of fresh bleach)
    12:30pm FC 7.5 CC 0.5 Added to bring to 14. Walls feel a little slimy; brushed. PH 7.3
    4:30pm FC 12 CC 0
    5:30pm FC 11.5 Added to bring to 12.5
    The only thing different is on Sunday:
    1) we put the ladders in. The outsides were scrubbed with bleach water. Could there be algae spores in the metal tubing? I took the ladders out and took the caps that sit against the pool surface off and only see dirt, nothing green. Left ladders out.
    2) pool floats were in the water on Sunday also
    Light niche was scrubbed at opening.
    I don't understand what is happening.
    Dec 2014
    Sydney, Australia
    43
    Why do you think you have a problem, your weather shows 30C & sunny, FC loss is to be expected, you have minimal CYA <40 could be 20 ??, 0CC, . What are you afraid of?
    8M x 4M Inground Concrete, 40k Litres, Waterline Tiles/Quartzon, Viron P320 VS Pump, Sand Filter(Glass Media) Astral VX-9 SWCG, Heatpump w/ Solar Cover. Zodiac V3 4WD Robot. Bullfrog A8D Spa(1800Litres).
    Richard320's Avatar
    Jan 2010
    19,056
    SLAM it again and leave everything in the water to soak, then. Leave everything in to soak while it's happening, too. If it's just a little slipperiness and high FC consumption, it should go fast.
    Check out
    Problem Found and Ideas needed
    Water problems
    Aug 2014
    Northern IL
    4,615
    Richard is the expert here, for sure. With a CYA of just under 40 (post #1), you need to get back up to 16ppm for the slam, not 12. Not sure if you were trying to slam today... Hope that helps!
