Results 1 to 17 of 17
Thread: Overshot FC
    Diane T.'s Avatar
    Apr 2015
    Alabama
    55
    Overshot FC
    Yes, slamming again. HD 2.5 inches of rain last Friday and algae started back Saturday. Overshot FC target of 28 to 35. Should I be freaking out? Vinyl liner and sun setting.
    IG 15,000 gal vinyl Grecian SW, Hayward SWG, Pentair whisper flow pump, sand filter, Aquacal ice breaker heat pump. Finished August 2015, screen enclosure, TF 100
    Jun 2014
    14,970
    Re: Overshot FC
    No freaking. It will sink back down soon enough. A short, one-time "oops" will be okay.
    Diane T.'s Avatar
    Apr 2015
    Alabama
    55
    Re: Overshot FC
    Thanks Splash. I'm still freaking. Ruined my birthday dinner. Added calculated amount Went from 10 to 21, so hubby added calculated amount to raise it to 28. Checked 3 hrs later and got 35. CYA was 70. Made the mistake of having the SWG on also I guess. BTW you were kind of right, I must not of slammed long enough the last time or I didn't bump up,the SWG enough with all the rain. My husband is ready to fill it in! He thinks all this testing is crazy.
    Just don't understand how the readings can all be good and the water crystal clear and it comes back in just a few spots on the edges. Must be dead circulation zones and it collects more evenly on the floor?
    Sorry just have to vent and try to not want to go backwash the thing and refill. I would end up in the bottom! Lol.
    Jun 2014
    14,970
    Re: Overshot FC
    No problem. We'll be here to try and help guide you. The FC will settle and you can focus on the path ahead .. SLAM ... or whatever needs to be done. You'll get it.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Re: Overshot FC
    Hi Diane,
    Dead spots on the 'edges' can produce algae. Always be sure and take a few minutes and brush pool walls once a week.
    If you didn't brush the walls while slamming, then you maybe didn't get it all.
    Most people stop the slam too quicly because they basically are tired of doing it and hoping for the best. Stick with it.
    WHen you think you're done, then keep slamming for 2 more days just to be sure, is what I tell people.
    Divin Dave,
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,866
    Re: Overshot FC
    I have to chime in here with my own experience in case it helps. As others said brush brush brush (something I resisted for far too long). I have had algae come back after a successful slam even when my testing showed higher than minimum CL for my cya and I'm also a SWG user.
    I found:
    Algae slightly behind my skimmer plates between them and vinyl
    Algae behind the framing of the lights between that and vinyl wall
    Algae in the cracks where my fiberglass steps met the vinyl wall
    Algae on vinyl behind almost every return
    I actually purchased a flat handle plastic kitchen brush and had the kids start getting in those cracks when they were in the pool. Places I was not effective with the long pole and brush.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Diane T.'s Avatar
    Apr 2015
    Alabama
    55
    Re: Overshot FC
    Thanks for the input. I have been brushing once to three times a day. I was sick most of the weekend so hubby had to take over and he brushed. I may have to brave the chlorine and get in there with a small brush like mentioned. You don't actually try to remove covers do you? My roots need lightening anyhow. Can an enclosure feed algae into the pool after a rain? I don't know that I have that just a thought. I would think the FC would kill it off.
    Also small bubbles on walls (degassing) good, bad, normal when all this going on?
    We've had pools before but never SW and never such a problem. My husband thinks I'm overthinking and over reading all this. A little OCD no doubt!
    Diane T.'s Avatar
    Apr 2015
    Alabama
    55
    Re: Overshot FC
    Update. Full sun all day. Spent the afternoon at the Drs and didn't get to check FC until this evening. 22.5 Now after my night of panic I need to raise it again. Do I have to check the CYA or is my start reading still good?
    Photo of my crystal clear pool attached. Maybe.Attachment 48718
    Jun 2014
    14,970
    Re: Overshot FC
    Looking good! So let's see ... still SLAMming? Until you pass the 3 SLAM criteria, maintain that SLAM FC. But you sure look to be very close. Have you done an overnight (OCLT) test? Might be time. Pool School - Perform the Overnight FC Loss Test (OCLT)
    Diane T.'s Avatar
    Apr 2015
    Alabama
    55
    Re: Overshot FC
    Texas, do I still aim for the original 28. I didn't retest anything else. The pool water has never been green, but looks crystal today. I will continue for another day at least. I'm afraid I might run out of chemicals though and I'll have to wing it. On order but 27 th earliest delivery. I'll can't do overnight tonight because I'm bringing the FC up right now.
    Thanks!
    Jun 2014
    14,970
    Re: Overshot FC
    Based om yesterday's comment about algae
    , I would continue to maintain the SLAM until you can do the overnight (OCLT) test. If you're really low on R-0871 drops, you could switch to the 5ml sample option (fill to 5 ml, each drop equals 1 FC). It's not as accurate as the 10 ml, but you will use half the drops until your replacement arrives. That way you can maintain the FC of 28 until you can test/pass the OLCT. If you haven't replaced a lot of water, everything else should still be the same. Your SWG is off correct? Definitely make sure it's off when you do the OCLT.
    Diane T.'s Avatar
    Apr 2015
    Alabama
    55
    Re: Overshot FC
    Thanks good idea on the chems. SWG is on super at the moment to bump up the FC. I know it's not as fast as liquid, but since it's oversized it can raise it pretty fast (that's how I overshot originally). I do know to turn it off for the overnight test. I'm plannining on winning this battle this time. Last time I passed the overnight test two nights in a row and obviously still failed.
    My neighbor just called me with pool problems. I asked what the chlorine was. Light yellow was the reply. �� They are total newbies.
    Casey's Avatar
    SW PA
    10,421
    Re: Overshot FC
    You should really use liquid during a SLAM. Make sure you're brushing your pool weekly. It is one pool chore that people would rather not do and they don't.
    Diane T.'s Avatar
    Apr 2015
    Alabama
    55
    Re: Overshot FC
    Thought I replied already. Thanks for the chem suggestion. I will turn the SWG off when ready to OCLT. Don't want to lose the battle this time! Thanks again
    Diane T.'s Avatar
    Apr 2015
    Alabama
    55
    Re: Overshot FC
    So now it pops up! Sorry. Brushing twice a day minimum. I strangely like to brush the pool. A touch of OCD. I know I should use liquid, but ran out and even though I drove right buy Walmart didn't have the energy to go in after sitting at the doctors for 3 hours. Tomorrow!
    Diane T.'s Avatar
    Apr 2015
    Alabama
    55
    Re: Overshot FC
    DONE! Held 26.5 overnight (not quite 28 level but wasn't going to adjust at 7 pm) 0 CC and I can see the slots in the screw heads in the deep end. Brushed and saw nothing. If that doesn't do it, I give! Of course I bought 4 jugs of pool chlorine yesterday came home and checked the pool. First conserve chem test - 38 freak out again. Redid with full 10 ml and got 31. Ok relax. Also had reordered another super size 081 to get it here before I ran out and paid extra for next day delivery. Now that I'm done slamming all my extra chems will probably arrive today. I guess I can check it to my hearts content now.
    Hubby wants to clean salt cell. Directions say ph should be 7.2 - 7.8. Must he wait for an accurate reading when FC is below 10? Thanks for the help and I hope I can enjoy the pool now.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: Overshot FC
    Yes, let it fall to below 10 before checking pH.
    Good job!
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
