Results 1 to 20 of 20
Thread: Newbie AGP upgrades?
    May 2016
    Minnesota
    11
    Hello everyone. I just bought our first pool this week (Intex Ultra Frame 22'x52") and am wondering what the usual upgrades are. The pool is still in the box and came with a 2500 GPH pump and canister filter, but I am planning on swapping this out for the Intex 3000 GPH Pump and Sand Filter. Is this a good setup? I was also thinking about going the saltwater route. Without getting into a Chevy/Ford type discussion, is this the more popular thing these days? Thanks everyone!
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    Re: Newbie AGP upgrades?
    Excellent decision on the Intex sand filter. A lot more efficient than the cartridge Intex type and easier to maintain! On the salt water question, on an Intex pool it will do you wonders. Be sure you invest in a good test kit to make your life a whole lot easier. We recommend the TF100. No complaints whatsoever out of it. Also, if you aren't a veteran in pool care, check out pool school on the upper right hand corner of this site.
    Great information awaits you! Also, please update your signature when you can to include your pool size, total gallons, and filter system! Will help us help you.
    Above Ground 30' by 54" 22,600
    Hayward S244T Sand Filter w/ 1.5HP Dual Speed Hayward Powerflo Matrix Pump
    TF100 Test Kit
    BBB ALL the way!
    Questions about pool care? Visit Pool School
    May 2016
    Minnesota
    11
    Thanks for the info. Im sure I'll have a lot more questions
    Intex 22' x 52" AGP 10,500 gallons
    Intex 2500 GPH Pump/Filter
    Intex 15000 gallon SWG
    May 2016
    Minnesota
    11
    What about a skimmer? Is one necessary? If so, which brands? Hayward I heard makes a nice thru-wall one. Is it a good idea to compromise the integrity of the wall to install one? I worry about the liner tearing where the screws are.
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    Personally, I would recommend a skimmer. You can get the Intex clip on ones, but I would still recommend a through the wall skimmer. Many of our members have taken the plunge and installed one. There are plenty of tutorials on YouTube, and I'm sure many members would be happy to chime in and give you tips on how to do it specifically.
    Brand wise, I'm a Hayward guy so I would personally recommend them. The one I purchased has a huge basket inside, which is typical for most haywards. Also about the liner, if you follow the instructions of members or videos you won't have any problems.
    TF100 Test Kit
    BBB ALL the way!
    Jul 2014
    Oakbank, Canada
    389
    The biggest drawback I see to having a through wall skimmer is the amount of water depth you loose. Mine is only a 48" pool which really is only about 42" of water at the highest point, and I do not want to lose another 6". I just use the clip on Intex one.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Quote Originally Posted by DarrelB View Post
    I feel the same way. Until I have to get all the fluffies and bugs out of the pool. I'm still on the fence.
    If you get the bigger filter, a vac is a good investment. I just use the manual type. Works great.
    A decent ladder can be a good upgrade also, especially if adults will be using the pool. We built a small deck and got steps. But in the interim, we borrowed a Confer ladder and it was sturdier than the wobbly ladder they come with.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Welcome!
    Single best thing you can buy after the pool itself is a proper test kit. You can take a few minutes to read the article in pool school, or just skip to TFTestkits.net. Nobody who has bought a speedstir with their kit regrets it, either. No lie.
    Lots of people install a through-wall skimmer. Lots of people install hard plumbing. Some great threads are listed here: Useful links for fellow Intex Pool Owners
    mbuice's Avatar
    Jul 2014
    Denton, TX
    95
    I have to agree about the skimmer. Even if you don't want one in the wall, a mounted one is better than none at all.
    18 X 34 AGP 7ft deep end, 22,300 gallons. 250lb sand filter, 2 speed 1.5 hp pump. TF-100 Test Kit.
    May 2016
    Minnesota
    11
    Which Intex sand filter/pump would you recommend? The 2800 gph or 3000 gph? The 3000 is $50 more.
    Sand filter upgrade is a must, we did that after one season with the crappy cartridge. I'd go for the bigger one if it's only 50$ more!
    The thing about putting a wall skimmer on an intex is that cutting the liner worried me, so we never did it. We did ok with the over the wall one and skimming manually every day.
    Sharkline 24' round 54" aluminum AG pool. Waterway 2HP 125sq ft. cartridge filter. Using k-2006 test kit.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,528
    In this order:
    1) a good test kit
    2) the biggest pump and sand filter you can find
    3) a through the wall skimmer
    4) a saltwater generator
    5) the Intex pool robot
    6) plastic margarita glasses
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    May 2016
    Minnesota
    11
    So if I go with the TF100 kit, what else do I need if I go saltwater?
    May 2016
    Minnesota
    11
    I'm starting to second guess the saltwater decision. It seems like a lot of above ground pools are deteriorating prematurely. Opinions?
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Quote Originally Posted by jeffchap View Post
    In this order:
    1) a good test kit
    7) hard plumbed using 1.5" PVC
    Starting day 5/25/2015 INTEX AGP 24'x12'x54" 8400 gal, with salt and borax, INTEX 16"sand filter, WM Hayward Skimmer, Intex SWG CG-28669, 1 1/2" hard plumbed PVC, Lil' Shark Vacuum With Leaf Canister, TF100 test kit, speed stir, K-1766 Taylor salt test
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Jun 2015
    Stockholm, Sweden
    250
    I second Jeffchap/Piolins list. Properly mounted above the seam, you dont lose any depth with a through wall skimmer, see the other threads on the subject. The Intex skimmer is better than no skimmer, but just barely.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Jun 2015
    Stockholm, Sweden
    250
    Quote Originally Posted by Piolin View Post
    8) Intex floating lounge chairs
    9) Intex floating beer cooler
    10) floating wireless pool speakers
    Jun 2015
    Stockholm, Sweden
    250
    11) wireless floating thermometer
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    156
    12) Porta potty
    13) BBQ grill handy
    14) Invites to all TPF members
    LOL!!
    Intex 20x52 above ground pool-
    8632 gallons
    1 man 4 woman Bullfrog Hot Tub
    http://www.flickr.com/photos/pitguy3/se ... 763801706/
    ROLL TIDE!
  20. Back To Top    #20
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Quote Originally Posted by ObWan View Post
    Seriously I don't think this is the case of a well balanced pool like the one you will find here, take in account that Intex pool are to be last only 3 or 4 years most times... Maybe more in some places...
