Thread: My levels....finally close. Should I mess with it any furth
    FC - 4.4
    TC - 4.4
    CC - 0.0
    PH - 7.5
    Hardness - 60
    Alkalinity - 85
    CA - 50
    Copper - .08
    Saturation Index - .80
    My FC was basically at 0. I added bleach and turned pool pilot on boost mode for a couple days. Now that it's inline I need to check it daily on 50% to see where things fall. Should I mess with anything else at this point?
    46k gallon vinyl, Intelliflo VF, Quad DE 100, Autopilot DIG60, Raypak R405a, Bravo Fury Auto Cleaner
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: My levels....finally close. Should I mess with it any furth
    CYA for an SWG should be 70-80.
    You should not use boost on your unit, it shortens the life of the cell. Better to boost the chlorine level only with liquid chlorine.
    Butterfly's Avatar
    South Carolina
    10,045
    Got salt
    You're done SLAMing when:
