Thread: Burnt hose
    Burnt hose
    I was just uncovering my equipment (which I take in my 2 spaflex hoses, pump and my filter-to-pump-hose-re-inforced-vinyl for the winter) and I found this (see pic) on my backwash hose(same type as my filter-to-pump) which I leave out. The filter and hose was covered with a blue tarp. This is my 6 year of doing this - never have I seen this before. I am in western pa -- could the heat under the tarp get that hot???
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    Re: Burnt hose
    Can't say I've ever seen anything like that before. You may want to replace the hose just to be safe! Should be pretty easy with the hose clamps.
    Above Ground 30' by 54" 22,600
    Hayward S244T Sand Filter w/ 1.5HP Dual Speed Hayward Powerflo Matrix Pump
    TF100 Test Kit
    BBB ALL the way!
    Questions about pool care? Visit Pool School
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    Re: Burnt hose
    Ours will end up looking like that from baking in the sun. After several years of being fully exposed the hose from the pump to the filter will look exactly like yours. The last one even started to feel tacky/sticky where it had turned brown. It's not very expensive at lowes or Home Depot to replace it, sold by the foot. Easy fix, just loosen claims and measure hose length and diameter before going to buy a replacement or just take it with.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Re: Burnt hose
    Thanks -- yeah I'll check Lowes for a new one -- Just never thought that it would "cook" like that.
    Casey's Avatar
    SW PA
    10,423
    Re: Burnt hose
    Oh wow... that is crazy.
