Thread: Hose leaking at return
    May 2016
    Ontario, Canada
    1
    Hi folks, new to the forum and have been doing some browsing but am hoping for a different solution than having to replace the hose.
    I filled my pool on the weekend and noticed a small leak coming from the connection from the hose the the return. I have tried tightening the two hose clamps but am still getting a small leak coming rom the connection.
    I have a return with a light built into it so I'm not sure how I can stop the water from draining from the pool if I were to replace the hose.
    I have also also tried sealing the connection with silicone but with the constant water leaking i can't get the silicone to set.
    Can an anyone recommend a solution that maybe doesn't involve replacing the hose, or a way I can stop the pool from draining out of the return if I remove the hose?
    i will post a couple pictures when I get a chance.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Hose leaking at return
    I simple expandable plug of the right size used inside the pool return while you complete the repair should do the trick?
    Isolated Spa - 345 Gallons
    Apr 2013
    Sacramento, CA
    2,769
    Potatoes work well in a pinch.
