Results 1 to 9 of 9
Thread: Loud Hayward Super II Pump
    gwarriner's Avatar
    May 2016
    Whitby, Ontario, Canada
    3
    My first post...my apologies if I leave out necessary details, overlooked post requirements or posted in the wrong forum.
    I have a 1HP Hayward Super II Pump that is going on 8 yrs old this fall. It has been working well without any major issues, however every year it seems to get louder and louder. It is not a high pitch squeal, rattle or a hum, rather (for lack of a better way to explain) it makes a rhythmic 'wuhh, wuhh, wuhh, wuhh...'. The pool equipment is on the same side of the house as our master bedroom on the 2nd floor, and it's getting loud enough that it can keep you awake at night. We do not have a timer on the pump, and used to have a UV sanitation system which required the pump to operate 24/7. We have since switched to a salt chlorinator so I suppose I could run the pump only during the day, but without a timer I would not really enjoy turning it on and off manually every day.
    One 'off the cuff' opinion I received was to replace the bearings, but after doing my own research it seems like this wouldn't help.
    Any one have any thoughts on what could be causing it to run so loudly?
    Cheers!
    Greg
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Loud Hayward Super II Pump
    Welcome to TFP Greg
    It sure sounds like a rebuild may bring it back to it's normal sound level
    Is this the pump?
    https://www.hayward-pool.com/pdf/Par...s/Super-II.pdf
    I hope this helps :
    pookiesunshine's Avatar
    May 2016
    Cincinnati, OH
    432
    8yrs sounds like a long time for a pump motor to hold up. seems like the bearings go very quickly any more. either rebuild the motor or replace it is my suggestion.
    30000 gal inground vinyl liner;sand filter w/glass media, nuvo uv, TF-100 test kit; 25 years on Baquacil, converted to TFP chlorine in 2016
    gwarriner's Avatar
    May 2016
    3
    Yes, that is the pump. A rebuild, huh? Is that typically less expensive than replacing a pump like this? Any idea how many more years I could expect to get out of it after it's been rebuilt?
    Thanks for the reply!
    Greg
    8yrs is a long time? I would have expected they would last much longer than that. Just goes to show what I know. Now to figure out whether to rebuild or replace, and if I replace it, do I buy the same thing?
    Jul 2013
    Fletcher, OK
    3,353
    Greg, If you really want to run it 24/7 I would go with a 2 speed pump replacement..
    yes, it is much cheaper to rebuild.. The next price would be to replace the motor and then the most expensive to replace the whole pump...
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    The wet side is pretty bullet proof. Its the dry side (motor), that will go. Specifically the bearings. Usually due to a leaking shaft seal. You can pick up bearings inexpensively, and shaft seal and do the job yourself. Less than $20 and an hour of time. Or you can get a rebuilt motor and new shaft seal. Then next expensive is a new motor, then whole pump. Increasing in cost. If changing out the bearings every 3 years for $25 or $30 or a rebuilt motor for $200 every 5-8 years or new motor $300 every 5-8 years. The choice is yours.
    Oct 2015
    Katy/Texas
    411
    If you really want to quite things down, get yourself a two speed motor. You will barely be able to hear it on low speed.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    gwarriner's Avatar
    May 2016
    3
    Thank you all for the info and recommendations! I may see what I can do myself, or get a local repair shop to rebuild the pump for me. I'd rather get as many years as possible out of this pump before replacing it, but when the time comes I will look into a 2 speed pump. Again, thank you all!
    Apr 2011
    Murrieta, CA
    2,360
    You won't need a whole new pump, just the motor.
