Results 1 to 7 of 7
Thread: Please Validate my Calculations for going on vacation
    Alwayswantedapool's Avatar
    Jun 2015
    York SC
    200
    I will be out of town for 6 days and trying to calculate how much trichlor Tabs I will need to put in the pool. I also plan on bringing the pool up to Slam level (24 PPM) just prior to leaving.
    I will start off with current measurements.
    FC 8 (this is the current level that I am maintaining FC)
    CC 0
    PH 7.6
    TA 70
    CH 50
    CYA 60
    As of right now, pool on average is consuming 2 PPM of chlorine per day, so that means I will need 12 PPM while I am gone. Looking at pool math, a 8 oz tab (I think that is what a tab weighs) will increase FC by 1.8. So with the requirement of 12 PPM while I am gone, I am going to need 7 tabs which will increase my FC by 12.6 and CYA by 7.7.
    Does that sound right?
    I will be running the pump on its regular schedule while I am gone and will make sure between the skimmer and the side drain that they are at about 50 / 50.
    I was thinking I could use cal-hypo since I could add a bunch of calcium with no negative effects but looks like that only comes in a powder.
    Thanks for looking, greatly appreciated.
    Mark, Pool: 30,000 gallon, IG Vinyl, Pentair Superflo Variable Speed 1.5 HP pump, Hayward S220T Sand Filter, Taylor k-2006 Test kit with speedstir. Dolphin Nautilus Plus.
    Hot Tub: Hot Spring Grandee 450 Gallons, Ace System (Salt water Chlorine Generator) Dichlor / Bleach method. Taylor K1766 Salt Test.
    38,407
    Re: Please Validate my Calculations for going on vacation
    You are missing the point that as you raise the FC higher above the normal level for a given CYA value, you will actually lose more ppm to the sun.
    How are you going to add the tablets? Do you have a cover?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    That sounds like a great plan, but I am not sure you will need that many pucks but like you said, it is not going to hurt anything as you know exactly what you are adding
    If your raise to SLAM level of 24ppm, how long will it take to return.. I would say the first 48 hours you will be down to about 14ppm, by day 4, probably down to 10...
    With that in mind you may be able to get away with 3 pucks adding 5.5 fc and 3.3 CYA, I am not the math wizard though so that is a guestimate
    Jun 2015
    York SC
    200
    I was going to put the tabs in a couple of the Chlorine floaters and nope, no cover.
    I get that bumping it up to slam will only give me probably a couple of days, 3 tops I would guess, counting on the tabs covering from there.
    I have never used tabs, how fast do they dissolve? Will the last 6 days?
    38,407
    In a floater, they dissolve pretty slowly.
    I think I would just get 1 floater and put 3-4 tabs in it. When you get home, you can pull them out and let them dry if you like to save them for later.
    Be sure there is nowhere the floater can get stuck up against the vinyl (like a ladder) as it could fade the liner due to the acidic nature of the tablets.
    Jun 2015
    York SC
    200
    Why are you thinking just 3 - 4 tabs? Just want to follow your logic.
    Great point on the floater, it will most likely end up at the steps or swim out if I don't tie it down someway.
    38,407
    Really so you only buy 1 floater. You are over thinking it
