Thread: Aqualink started on time then 5 minutes later stopped. Won't start.
    May 2016
    Houston, TX
    1
    I changed the battery outside and in the PDA. I hear the relays clicking but no juice to the motors. Help!
    Jul 2015
    Central Valley CA
    1,107
    Re: Aqualink started on time then 5 minutes later stopped. Won't start.
    The breakers that run the pumps are usually different than the one the Aqualink panel is connected to. Check for tripped breaker either in sub-panel or house main panel. Then check for tripped GFCI lastly look for a reset button on the pump motor.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
