Results 1 to 7 of 7
Thread: Consensus on fix for Liquidator White Stuff problem?
    Aug 2014
    Northwest Florida
    9
    I've read through all the Liquidator WS troubleshooting threads that I could find, but all posts were from back in 2008 and I never saw a "final disposition" on best approach to prevention. Just had my first bout with the WS, clogging the flow control valve, so hoping someone can point me in the right direction.
    Regards,
    Matt
    20,000 gallon in-ground vinyl pool, Hayward Super II pump, Hayward S244T sand filter, C201 Liquidator 3/8" upgrade
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Consensus on fix for Liquidator White Stuff problem?
    Welcome to TFP!
    Not really a consensus. Probably either the low pH or high chlorine level causing calcium to precipitate.
    Aug 2014
    Northwest Florida
    9
    Quote Originally Posted by JohnT View Post
    Welcome to TFP!
    JohnT, thanks for the quick reply. Please clarify - you wrote "low pH", did you mean high pH? What I gather from other posts is the chlorine saturated water layer in the Liquidator is high pH.
    Also, I see from your sig that your pool and equipment similar to mine. Curious if you would share the typical range you keep your pH, TA, CH and CYA, and do you ever get WS in your LQ? (I suspect my bout with WS was due to pH (7.8 - 8.0) and TA (100-120) levels too high...
    Thanks again
    SW Indiana
    9,199
    Quote Originally Posted by Mattman1 View Post
    Thanks again
    Yes, I meant high pH!
    My calcium is near zero. TA about 135ppm. pH pretty close to 7.5, but it tends to creep high. CYA about 40ppm and chlorine about 5ppm.
    I get a salty looking deposit in the bottom of my Liquidator, but the hoses just get slightly milky looking over the years.
    Ellington, CT
    262
    My CH is around 100 - 120 ppm, TA about 60. PH 7.4 to 7.6 and drifts high on occasion. CYA of 40 ppm. I also get an accumulation of salt at the bottom which according to the Liquidators manual is normal, just don't let it get deeper than 2 inches. My tubes also get cloudy, but never had problems with WS.
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    I have the LQ and have never had a prob with white stuff. My
    TA = 70
    CH = 225
    ph = 7.7
    CC = 0
    FC = 4
    Borates = 40 ppm
    Someone here said to wait until after first year on Borates but I added anyway. The consensus seems to be that it prevents the white stuff when you use the LQ. And it seems to make the pool surface sparkle more. I need to add more boric acid now, we have had 74" of rain in the last 12 months, a record. About 36" since I opened the new pool three months ago.
    30,000 gal free-form IG w/ spa, PebbleSheen Blue Surf, Pentair cartridge filter, Pentair 3 HP Intelliflo, extra pump that is way over-sized for weeping moss rocks, Dolphin Oasis Z5, municipal water, all built Jan-Feb 2016. TF-100, SpeedStir, Liquidator 3/8", borates. My build thread http://www.troublefreepool.com/threa...-in-Cypress-TX
    Aug 2014
    Northwest Florida
    9
    Really appreciate all the replies.
    One additional observation... my LQ's WS problem gets noticeably worse if I add more than 2.5 gallons of liquid chlorine at a time, or if the level of liquid chlorine in the LQ approaches the top of the white extension tube.
    I suspect the problem may be caused by the combination of CH = 125, TA = 120, pH = 7.8, plus a high chlorine saturation level in the LQ's water layer... I plan to work on reducing CH, TA and pH and see how that goes.
    Matt
