Thread: Opened pool and pump is dead
    jgjh151's Avatar
    May 2012
    Glenville, NY
    39
    Opened the pool this weekend and the pump wouldn't start. I'm going to be without one for 3 days so I'm wondering what I should be doing with the water to up and running again.
    The pump us humming and not moving, several years old. Don't feel like disassembling so I bought a new one and on it's way.
    Will test water this evening. After opening and figuring I'd be without filter for a few days, I put in 4 jugs of bleach to hold it over. I have the submersible pump in the pool to circulate the water. Picked out what I could with net. Not much in there, some dirt here and there, I can see the bottom of deep end, little cloudy.
    Besides testing and getting levels to what I can without a filter, anything else I should be doing?
    Jon
    21,000 gallons, Hayward sand filter, IG, 16x32 kidney, Vinyl, Hayward Super Pump 1hp, Flow rate: ?
    Jun 2014
    15,145
    Re: Opened pool and pump is dead
    You've addressed most everything Jon. Adding some bleach and trying to circulate the water as best as you can. Cleaning-out debris as well. All good points. Your test results may tell you more later.
    jgjh151's Avatar
    May 2012
    Glenville, NY
    39
    New pump arrived, I'm wondering what the best plumbing pieces I should get to make these 2 connections.
    Something like this:
    http://g04.a.alicdn.com/kf/HTB1zRcdI...ont-b-Pipe.jpg
    The black pieces on the pump say 2.5. The white PVC says 1.5.
    Jon
    jgjh151's Avatar
    May 2012
    Glenville, NY
    39
    Ended up getting two of these and was pretty simple:
    http://www.pvcfittingsonline.com/437...FYpZhgodzLQG7A
    Jon
    Jun 2014
    15,145
    Very good Jon. Hope it all works-out for you.
