Thread: SAm Light Ring Leaking; Stripped Screw
    phenwick's Avatar
    May 2009
    Metro St. louis Mo.
    11
    After suffering mysterious water loss, we found it leaking at the light ring from a stripped screw. we used some window caulking strip to temporarily stop it last season but it's not a permanent fix.
    Would replacing with a larger SS screw (same length) be the proper fix?
    Dave
    22,000 IG vinyl; Swim Out; Sand Filter
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: SAm Light Ring Leaking; Stripped Screw
    Welcome to TFP!!
    When I've run into this problem, the first thing I do is wrap the screw with ~ 6 layers of teflon tape - this works ~ 50% of the time. If the teflon tape doesn't work, I use a slightly larger screw or one with more threads
    Please let us know how it works out 8)
    Luv& Luk
    -Ted
    phenwick's Avatar
    May 2009
    Metro St. louis Mo.
    11
    Thanks for the reply. I will try the tape first. I assume I need to get enough bite to hold seal in place?
    Dave
    Mar 2007
    4,160
    Yes, you need to have the screw 'bite' enough to keep the pressure on the faceplate so it seals
    Luv& Luk
    -Ted
