Results 1 to 7 of 7
Thread: Want to install overflow outlet. What concerns??
    deweypip's Avatar
    Jan 2012
    Richland, PA
    115
    Would love to put on an overflow outlet. What's involved? How scary is it to cut hole through side of pool and liner?? What tools??
    Is this something to sub out?
    deweypip
    24x54 Sharkline Matrix
    Hayward 1 hp Powermax single speed pump
    Hayward ec50ac DE filter
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    Re: Want to install overflow outlet. What concerns??
    You could always filter to waste to drain water. I've heard of people cutting additional holes in their wall for returns, so I'm sure it's possible. You are however added a weak spot for potential rust issues down the road as you are trimming the galvanization away. Although they have galvanization solutions to strengthen the coating.
    Above Ground 30' by 54" 22,600
    Hayward S244T Sand Filter w/ 1.5HP Dual Speed Hayward Powerflo Matrix Pump
    TF100 Test Kit
    BBB ALL the way!
    Questions about pool care? Visit Pool School
    Jul 2015
    Central Valley CA
    1,109
    Do you have a skimmer? If so perhaps you could drill a whole through the back of the skimmer just slightly higher than the ideal water line. then it would just be a matter of some tubing or PVC plumbing to where ever you want the water to go.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    deweypip's Avatar
    Jan 2012
    Richland, PA
    115
    Actually thought of drilling a hole in the skimmer. There is actually a flat spot where I could get a 1" hole. That would probably be the best plan.
    Casey's Avatar
    SW PA
    10,461
    May I ask why you are looking to do this? Is it because you have a DE filter and you lose DE? I have a DE too. I actually don't mind the excess water. The only thing it doesn't do is skim the top of the water. Once July gets here, I'm forced to throe the hose in.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Just drill a hole in the skimmer body and screw in a bulkhead fitting. Then attach a vinyl hose and trail it off to wherever you want it to drain.
    deweypip's Avatar
    Jan 2012
    Richland, PA
    115
    With all the rain this Spring, a few times I had to pump out water. Water was actually overflowing through my skimmer and landing right next to pool base. Not looking to eat out area around base of pool. Overflow fitting which would lead water away from pool, and not having to pump out pool would be "piece of mind", especially when out of town.
    Richard320---I think this is the way to go. Thanks all.
