Thread: Inground Pool / SPA - Pump not sucking water into SPA
    May 2016
    Philadelphia
    2
    Hey,
    I recently purchased this home and have been fooling around with the pool. My two biggest issues right now are....
    Pool Specs:
    D.E. Filter 48 sq ft
    21 x 42 feet (700 sq ft)
    32,000 Gallons
    2 Return lines and 1 Drain
    Gunite Shell
    Spa (4 Jets, 2 floor drains)
    1) I can clearly see bubbles in the Pump basket when running. When doing a water test on the pipes I find that the pipe coming into the pump is sucking air as the bubbles disappear when the water hits it. tried to seal it but its proving troublesome getting a good seal underneath the pipe as some bubbles are still present. The pool portion is spitting noticeable, but smaller, air bubbles and the pressure is lower than expected (10 psi and jet stream feels weak) yet the one SPA Jet is strongly pushing out water with air bubbles every 3 seconds or so.
    2) The pool has three pumps one for the spa, a booster, and one for the regular portion of the pool. When I click the button in the ground for the SPA The air blower turns on and the SPA pump is definitely spinning however I do not see any water movement at all in the basket, also there is a lot of debris from opening the pool and I don't notice that being sucked into the pump either. The drains were both plugged and I removed them before operation.
    Any Help would be gladly appreciated.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Inground Pool / SPA - Pump not sucking water into SPA
    Welcome to TFP
    Great explanation but we are going to need some pictures to help out, if you could get us pictures of all the equipment, spa, and pool that will help us see what is going on and maybe able to get you going
    Could you also please fill out your signature with your equipment, it helps
    Trouble Free Pool
    May 2016
    Philadelphia
    2
    Sorry for the delay, the good news is I got the Spa pump working and its pulling water through the drains now. The air is still present no matter what I have done so far.
    I also notice some white particles floating on the top of the pool is this dead algae, if so will shock or liquid chlorine remove it? I have used 10 Gallons of liquid chlorine to date and the water/algae cleared up much better than the images I currently have. (FC level is currently at 1)
    Not sure if you can see it on the surface of the water, I did a little digging the white stuff on top is some sort of weed like pollen (Dandelion).
